trans making noise
trans making noise
My friends vx just recenlty started to make a tapping noise. The trans shifts fine in all gears. The sound goes away when you press on the clutch, but when you let go the noise comes back. Could the problem be the throwout bearing?
Re: trans making noise (njracer)
is this a DEFINITE answer!? my trans is doing the same thing but im scared to trust a guy with a post of 20 (no offense).
EDIT: and it only does it when im driving. when im parked it doesnt make a noise?
Modified by JDM-ish at 12:20 AM 4/1/2008
Why does everyone always point at the throwout bearing.
It's not the throwout. the only time that thing is spinning is when the clutch pedal is DOWN, so it would have the opposite symptoms you're getting.
Do a search on the input shaft bearing, or ISB. It's also in the FAQ at the top of the forums.
Re: trans making noise (JDM-ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-ish »</TD></TR><TR><TD CLASS="quote"> it only does it when im driving. when im parked it doesnt make a noise?
Modified by JDM-ish at 12:20 AM 4/1/2008</TD></TR></TABLE>
You, however, are something else, as it's only happening under load. Might want to start your own topic.
TimelessLlama
Transmission & Drivetrain
09-24-2018 01:59 PM
