stock LS Turbo .. ( reliable and safe to run at wat psi)???
Old May 19, 2008 | 12:42 AM
asocallocal's Avatar
Default stock LS Turbo .. ( reliable and safe to run at wat psi)???
Stock Ls motor
mini ram turbo manifold
t3t4 turbo 50 63 trim
fast turbo line
turbonetic wg 7psi spring
greddy bov
450cc injectors
that is the set-up...
at wat PSI should i run this motor at to make decent power and yet reliable enough to last for yrs...
O YEA, THIS IS FOR MY DAILY DRIVE AND I WILL BE PUTTING ABOUT 70MILES ON THE MOTOR A DAY.
Modified by asocallocal at 10:02 PM 5/19/2008
Old May 19, 2008 | 01:01 AM
RedneckRicer's Avatar
what ever your tuner can do. cause its all in the Tune you can have the best parts best EMS and shitty tuner and you basically flushed your money down the drain.
Old May 19, 2008 | 01:22 AM
Default Re: stock LS Turbo .. ( reliable and safe to run at wat psi)??? (asocallocal)
for sure....
i was planning on running the turbo with just a chipped ecu. good idea or bad?
Old May 19, 2008 | 01:24 AM
Bad idea. you want it to last for years then get it tuned. not saying it will last for years cause bearings do wear. Clutches go out. the more you beat on it the more than likely something could happen.
Old May 19, 2008 | 05:04 AM
sneakysneaky's Avatar
Default Re: stock LS Turbo .. (asocallocal)
ive had good success with a chipped ecu and tuning on crome.
lots of ppl do it. i would worry more about timing and af being
at safe levels and not making huge numbers. dont worry about psi
as much as power. around 250-300 whp seems to be decently reliable
and is still alot of fun.
Old May 19, 2008 | 08:25 PM
with the set up i got, i just want it to last along time. 200whp ot a bit more is fine with me, just as long internal is not being stressed out too crazy.
what should i do with the set-up to make decent whp and be super reliable... i dont mind boosting at 7-8psi either...
is there other parts or things i should buy b4 slapping this on? im only using a boost gauge, would i need anything other ones?
and with crome, is that just a chipable chip? i have a chipped ecu but i dont think its crome/uberdata.
Old May 19, 2008 | 11:33 PM
wideband 02 sensor and oil pressure gauge is nice to have as well. rather have those 2 than a boost gauge.
If you have a chipped ecu then you are Crome/uberdate ready
Old May 19, 2008 | 11:42 PM
cool. do i need a FMU?
Old May 20, 2008 | 03:48 AM
aladdin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">cool. do i need a FMU?</TD></TR></TABLE>
Stay away
Old May 20, 2008 | 07:15 PM
wat else to do i need to get this started?
bigger fuel pump? turbo timer? bigger exhaust n piping? ect....
wat sizes?
Old May 22, 2008 | 06:49 PM
i guess this is all i need to run the turbo set-up safely right?
fast turbo line
greddy bov
450cc injectors
<U>im getting</U>:
oil pressure and air/fuel guages
255 fuel pump
2 1/4 piping (allmotor/ turbo maybe?)
thats it. hope it turns out good
Old May 28, 2008 | 04:43 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">Stock Ls motor
fast turbo line
greddy bov
450cc injectors
Modified by asocallocal at 10:02 PM 5/19/2008</TD></TR></TABLE>
7psi will be reliable for years. You could have it tuned to 11psi on your stock map. Id Daily it on 7psi though and bump it up to 10psi on occasions.
If those are DSM injectors make sure you use a resistor box.
Not sure what car this is, but 10psi should net you around 240 to 280whp depending on your setup. In a 92-95 civic, I've been 11.9 @ 115 on 10psi. So that plenty for a daily.
Id look into getting a oil restrictor oil feed flange. This will help your turbo survive longer under high oil pressures from out engines.
Use a direct vacuum/boost source for your waste gate to help regulate boost.
Drive it normal and beat on it on occasion because beating anything puts wear on parts, stock or modified.
Run 10w40 oil. I use regular Mobile. (cheap stuff)
Check your oil and fluids frequently.
Change your engine oil every 1500 to 2000 miles if you can. It now lubes your high horsepower engine and your extremely hot turbo.
Keep High Test octane in the car, always. (91,92,93,94)
Don't see a intercooler listed, but thats a must have. It helps lower air temps A LOT as im sure you know. Ive tested mine in the past at 10psi. 210-240 degrees before intercooler and 90 to 97 after the intercooler.
Hmm. Have fun and if you run into problems. Ask us some more questions
Old May 28, 2008 | 04:52 PM
JDMs1eeper's Avatar
If you knew someone who REALLY knew what they were doing. You could use a 12:1 FMU.
Ive seen it work good to around 7-8psi on a LS. After that (10psi) AFR's started to be in the high 12.5:1 to 12.9:1
My 98' LS dyno'd 244whp @ 8psi on a FMU years ago. It was on that setup for a year before going Uberdata when that first came out.
Try to look into some kind of engine management like fuel pump, Uberdata, Chrome, Hondata, Neptune... thats the best way to keep a engine healthy.
Old May 28, 2008 | 05:15 PM
SpoolnG2's Avatar
Default Re: stock LS Turbo .. (JDMs1eeper)
Dont even try the FMU idea. Yes it works, but is it really safe?? In my opinion no. If you understand how a FMU works you would know that since its a 12:1 its increasing the fuel pressure 12psi for every pound of boost.
So ..... Base Pressure = 42 + (12psi (fuel) x 8psi (boost)) = 138psi of fuel pressure on a stock injector. Sound safe to you?
Just get the hondata or whatever tuning system you decide to use...just not a FMU
Old May 29, 2008 | 07:14 PM
B and B's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">
Don't see a intercooler listed, but thats a must have. It helps lower air temps A LOT as im sure you know. Ive tested mine in the past at 10psi. 210-240 degrees before intercooler and 90 to 97 after the intercooler. </TD></TR></TABLE>
What kind of intercooler do you use? That sounds pretty effificient
Old May 30, 2008 | 05:56 AM
0bd1_Kanobe's Avatar
Default Re: stock LS Turbo .. (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Dont even try the FMU idea. Yes it works, but is it really safe?? In my opinion no. If you understand how a FMU works you would know that since its a 12:1 its increasing the fuel pressure 12psi for every pound of boost.
Just get the hondata or whatever tuning system you decide to use...just not a FMU</TD></TR></TABLE>Couldn't have put it better myself! Dont take the cheap route out and get hondata or a good management. FMU and motor life do not go hand in hand, yes you can make it work but the question is for how long? Good luck with your build
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
Gamefreak0109
21
Jun 8, 2007 02:00 PM
fickel_8
Nov 10, 2006 01:27 PM
redcivic44
Feb 6, 2006 05:33 PM
crx90rcr
Aug 27, 2004 07:00 AM
