Has anyone ran into this problem?
Old May 18, 2008 | 09:45 PM
OneCrzySetup's Avatar
Default Has anyone ran into this problem?
I pretty much have a brand new 70mm skunk 2 throttle body.. the throttle plate sticks inside which is creating my motor to rev out. while im stopping and driving? should i clean it? or sent it back to skunk 2? any suggestions?
Old May 19, 2008 | 04:02 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Has anyone ran into this problem? (OneCrzySetup)
Remove the air intake and rotate the throttle by hand to see if there is any obvious interference. Have you checked the throttle cable for free movement as well?
Old May 20, 2008 | 09:05 PM
Default Re: Has anyone ran into this problem? (Dogginator)
yeah the throttle cable is good. i drive the car and it gets stuck at like 3 - 4 grand. im going to take it apart and clean it tommorow. what else should i do?
Old May 21, 2008 | 05:22 AM
Acidcrakker's Avatar
Grease the Throttal spring, and the hindges on the throttl plate.
Old May 21, 2008 | 07:55 AM
azproimports's Avatar
Most of the time its the plate its self ... you paid good money for it, so send it back there good with it they know that some of theme do this ... dont waste tour time ...
Old May 24, 2008 | 01:12 PM
Default Re: Has anyone ran into this problem? (azproimports)
clean the throttle body, still getting stuck.. should i send it back to skunk 2?
Old May 24, 2008 | 07:21 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneCrzySetup &raquo;</TD></TR><TR><TD CLASS="quote">clean the throttle body, still getting stuck.. should i send it back to skunk 2?</TD></TR></TABLE>
If it is not something obvious, send it back.
Old May 24, 2008 | 10:11 PM
Its weird, i drive the car when i shift it, the throttle is fine, i give it alittle gas, and boom it sticks at like 4grand. i tap the gas again and the rpms go back down.. The trottle plate wasnt sticking at all when i cleaned it. not a clue what it could be.... someone said to greese the plate.. what kind of greese should i use?
Old May 25, 2008 | 04:29 AM
Dogginator's Avatar
Daisy... Daisy...
Could your throttle cable or gas pedal be sticking? Are you using the stock throttle cable and throttle rotor? Post a picture of your setup showing the cable mount and rotor.
If you ran an ITR type throttle cable mount with a GSR throttle rotor (B18C1 throttle rotor is unique), it could be causing an issue.
Old May 25, 2008 | 08:51 AM
VRD^don's Avatar
your throttle plate. the two screws that holds in it place, loosen those and adjust the plate and tighten it down, doesnt hurt to put alittle red loctite on there.
obd1_crx
Jun 12, 2007 05:42 AM
smokedyou19
May 10, 2007 05:15 AM
Hond@
Jan 19, 2007 04:28 PM
hatchish
Sep 12, 2005 05:38 PM
clutcher
Apr 21, 2005 05:25 PM
