AEM EMS Questions
From reading past posts, here's what I need for my '98 GSR:
>30-1020 AEM EMS
>DSM 450s or some 550 injectors
To install the EMS, will I be splicing wires, or is it a direct plug-in replacement?
Does the unit fit in the stock ECU mounts?
I have a Blitz SBC-iD boost controller.. I don't think I can just use the solenoid off
of that one, so I'm guessing that I need to somehow connect the EMS and the boost
controller together?
Am I forgetting anything I will need to purchase?
>30-1020 AEM EMS
that is correct... you dont need to spliec anything its plug and play. You need to run your wires to your boost control soloniod which is GM part runs around 20 bucks at most dealer some times cheaper.
ill answer some of it.
1st. its a DIRECT plug and play!!!! no splicing wires.
2nd. I dont think it will fit the stock ecu mounts(but i could be wrong)
3rd.the ems can control boost. you just have to buy a $15 gm part and wire it up. SELL THE boost controller for some extra cash!
4th. just buy it!
and some injectors
4th. just buy it!
and some injectors
h22_crx
Feb 5, 2007 08:09 PM
dunkd
Jan 28, 2005 10:40 AM
