innovative boost controller
Old Jul 19, 2006 | 04:46 PM
The Jacko's Avatar
Default innovative boost controller
I have a innovative boost controller and i was wondering if the aem ems could trigger the boost controller so that it could which to different boost stages.If there is,could it be done by speed?
thanks
Old Jul 19, 2006 | 06:37 PM
DaveF's Avatar
Default Re: innovative boost controller (The Jacko)
the innovative should be able to do stages on its own.
the aem can also control a boost solenoid and do it by speed.
Old Jul 19, 2006 | 06:51 PM
The Jacko's Avatar
Default Re: innovative boost controller (dturbocivic)
I know that the innovative boost controller can do individual stage, but I don't want to have to use the button or clutch. If the aem can do it can you tell me how. I appreciate it very much.
Thanks
Old Jul 19, 2006 | 07:03 PM
DaveF's Avatar
use a solenoid from your innovative controller, hook it up to the boost solenoid output from your aem. hook up the vacum lines. then play with the AEM to get everything how you want it. ( sorry if im vague, i know the aem can control a boost solenoid, but havent gotten to use my **** yet, so i cant tell exact details.)
Old Jul 20, 2006 | 02:12 PM
dome's Avatar
the new innovative boost controller can used in time base mode too. they have some new options.
Old Jul 21, 2006 | 07:29 AM
ykracing's Avatar
Default Re: innovative boost controller (dome)
personally, I would use the AEM to control a solenoid for boost, but, if you really wanted to trigger the stages on the innovative, Im fairly certain you could (in theory) use the auto tranny shift output to change it based on load/rpm/veh. speed..
never done it, and not 100% sure, but most likely its possible..
again, you should just simplify the whole thing and let the AEM control boost.
Modified by ykracing at 4:20 PM 7/21/2006
Old Jul 30, 2006 | 05:52 AM
The Jacko's Avatar
Default Re: innovative boost controller (ykracing)
just got a aem boost sld but don't know how to set it up need help
thanks
Old Jul 30, 2006 | 08:36 PM
jep's Avatar
jep
i am trying to setup my aem to control boost as well. look here http://forum.aempower.com/forum/index.php there is lots of good info.
Old Jul 31, 2006 | 06:12 AM
boostedh22a's Avatar
being that the innovative has a increase and decrease solenoid I don't think that the AEM can control it??? not sure on that?? just use the innovative in timed mode, once you have that figured out it will work just as good
QuarterMileMaster
Jan 22, 2008 08:23 AM
delslo93
Aug 13, 2006 06:06 PM
firstclassjdm
Apr 11, 2005 07:05 PM
PyroVTEC
Jun 7, 2002 11:51 AM
