best boost controller for my application?- AEM EMS, mbc, ebc?...
Old Jan 27, 2005 | 06:29 PM
dunkd's Avatar
Default best boost controller for my application?- AEM EMS, mbc, ebc?...
I plan on buying the AEM EMS and was wondering which boost controller would suit my needs the best... I have a tial 38mm wastegate plan on running about 12psi ~330hp on the street, then 20psi ~400hp in racing mode.
With the AEM EMS it has the boost gear control which the avc-r offers so i dont need that... I think that I will just need a simple manual boost controller? Nothing electronic, fancy and expensive. However, I do want quality.
I was looking at the Hallman EVO mbc with the adjuster that runs to the cabin. I like the idea of just being able to turn the **** without having to pull over and pop the hood. I have researched it and it seems like no one seems to have problems with it.
Is there anything that I am overlooking, or dont know about, that may effect my reasoning on which boost controller to go with?
Thanks!
Old Jan 27, 2005 | 06:47 PM
Brian_92GSR's Avatar
New User
Default Re: best boost controller for my application?- AEM EMS, mbc, ebc?... (dunkd)
If you're buying an AEM then all you need to do is buy a GM solenoid and you'll have more control over boost then any standalone boost controller. Once tuned, you can wire a HI/LOW boost switch as well.
Old Jan 27, 2005 | 06:58 PM
dunkd's Avatar
awesome, i read into that and found that all i am going to need is the the GM boost solenoid for ~30$. Everything can be controlled through the EMS... Just one more reason AEM wins me over...
Old Jan 27, 2005 | 08:28 PM
Muckman's Avatar
Moderator in Chief
Default Re: (dunkd)
The AEM has RPM/TPS, Vehicle Speed, or hi/lo switch boost target methods. But no Gear dependent target method. For the most part that may not matter as you can do almost the same thing with the speed method.
Another thing to keep in mind is the fact that if your using the AEM as your boost controller its one more subsystem you'll have to tune. That section isnt real hard to tune but it certainly isnt as easy as turning a **** on a MBC. This gets complicated if your trying to tune fuel/ignition at the same time your fighting with the boost control to maintain its boost target without overboosting. Just food for thought.
Old Jan 27, 2005 | 10:25 PM
PrettyLude's Avatar
i have the sbc-id and the power meter from blitz works good together and has can have speed map together, which is similiar to mapping boost by speed
Old Jan 28, 2005 | 07:42 AM
dunkd's Avatar
so a cheap MBC may be a simpler route than using the GM solenoid?
Old Jan 28, 2005 | 07:58 AM
Aggressive Racing's Avatar
Default Re: (dunkd)
Why not just use the Turbo XS dual stage,it's like $130 and works great.
SKUNK2 stg 2 cams:$600
Crower B18 stroker kit for all motor,95mm str crank,rods and pistons 82mm bore 13:0:1comp:1800
2 sets of TYPE R cams from 98 and 01:$450 a set **The 98 set was sold**
A GSR block sleeved by Z10,closed deck O-ringed,includes crank:$1500
CP pistons used 743miles on them 12:1comp 81.5mm bore,may need new rings:$200
NX nitrous kit new in box wet shot:$575
Turbonetics 62-1 bb turbo retails for 1300 selling for $900
If you need DYNOTUNING in the TRISTATE area visit http://www.aggressivemotor.com
Also for sale is my DYNOJET 248X http://cgi.ebay.com/ws/eBayISA...&rd=1
ALL PRICES ARE NEGOTIABLE SO DONT HESITATE TO ASK!!!!!!!!!!!!!!!!!!
Modified by aggressivemotorsports at 7:07 PM 1/20/2005
Call for Prices 201-296-0003
Old Jan 28, 2005 | 08:18 AM
DaX's Avatar
DaX
Loved
Community Favorite
If you're looking for simplicity, any ball and spring type MBC will be inexpensive, simple, and efficient. I'm usint the Turbo XS single stage MBC....'set it and forget it.'
Old Jan 28, 2005 | 09:27 AM
SPOOLINmatt's Avatar
Default Re: (DaX)
5$ needle valve works perfect for me.
Old Jan 28, 2005 | 10:40 AM
tgreaves's Avatar
Default Re: (arsenic57)
Using the gm boost noid with the AEM EMS is a little bit of a PITA to setup but once you get it working correctly you can do almost anything with it..
QuarterMileMaster
Jan 22, 2008 08:23 AM
The Jacko
Jul 31, 2006 06:12 AM
firstclassjdm
Apr 11, 2005 07:05 PM
PyroVTEC
Jun 7, 2002 11:51 AM
