Going with Bigger Cams! Help!!!!!1
Old May 18, 2008 | 02:57 PM
EG6 Poe's Avatar
Default Going with Bigger Cams! Help!!!!!1
JDM B18C Sir-G
Head has no porting
already installed is Buddy club spec 3+ cams/stock gears
skunk2 valvesrpings/retainers
Skunk 2 IM
Stock block (bottom-end)
I think stock comp ratio is 10.6 on a JDM B18C motor.
Can I go skunk 2 stage 2 cams? I dont really like the Buddy Clubs because they kinda lack top end power (I like the mids too but will sacrifice for top-end)
Thank you.
Old May 18, 2008 | 03:11 PM
Rollo Lawson's Avatar
u won't see maximum gains without a proper tune and not having the cams degree'd. if ur looking for a drop in cam, look itr/ctr. s2s2 without a tune and stock cam gears will net u less power than the bc3+'s
Old May 18, 2008 | 05:24 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Going with Bigger Cams! Help!!!!!1 (EG6 Poe)
Like Rollo said, a tune with s2s2 is a must.
Old May 18, 2008 | 05:42 PM
EG6 Poe's Avatar
Default Re: (Rollo Lawson)
so i can run skunk stage 2 (not pro) on my 10.6 compression with a tune??? I have the skunk valvesprin/retainers too.
Old May 18, 2008 | 05:55 PM
mar778c's Avatar
Community Builder
Default Re: (EG6 Poe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Poe &raquo;</TD></TR><TR><TD CLASS="quote">so i can run skunk stage 2 (not pro) on my 10.6 compression with a tune???</TD></TR></TABLE>
Yes
Old May 18, 2008 | 06:23 PM
UncleD's Avatar
Default Re: (mar778c)
Before pulling the cams, I would look into a good header and exhaust then get it tuned. Your cams are fine, no reason to pull them out yet.
Old May 19, 2008 | 08:10 AM
EG6 Poe's Avatar
Default Re: (clean rice)
I have already have a DC Sports 4-2-1 header, hi-flow cat, and Tanabe concept G exhaust..
Will there be that much of a difference between my spec 3s and skunk 2 stg 2 cams.
Old May 19, 2008 | 08:38 AM
all-mtr-teg's Avatar
[QUOTE=EG6 Poe]I have already have a DC Sports 4-2-1 header, hi-flow cat, and Tanabe concept G exhaust..
Will there be that much of a difference between my spec 3s and skunk 2 stg 2 cams.[/QUOTE]
In a daily driver where you don't see revs above 6k rpm much, the BC3 cams will dominate, if its a drag car that revs about 6k rpm constantly then the s2s2 cams will dominate.
I love the BC3's in my dd, and the Blox B's which are pretty damn close to s2s2's in my weekend drag car.
Oh, and like clean rice said, get a better header, that DC header is junk. Look into a hytech or rage, at least a edelbrock header and do the 2.5" collector mod.
Old May 19, 2008 | 08:50 AM
JakeSpec's Avatar
Default Re: (all-mtr-teg)
(all-mtr-teg)
where is the thread with the header mod for the JG proflow header?
Old May 19, 2008 | 09:22 AM
Default Re: (JakeSpec)
Ask and you shall receive
https://honda-tech.com/zerothread?id=1226335
Old May 19, 2008 | 09:39 AM
FST GSR 1's Avatar
I am actually running a pro flow header that I modified currently. With exhaust that doesn't sound anything like an import all custom made by me for under 500$. I do have engineering drawigns for it all however and 3D models.
Old May 19, 2008 | 10:56 AM
Default Re: (FST GSR 1)
Solidworks?
Old May 19, 2008 | 11:43 AM
FST GSR 1's Avatar
Yes sir...
Old May 19, 2008 | 02:48 PM
JakeSpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Ask and you shall receive
https://honda-tech.com/zerothread?id=1226335</TD></TR></TABLE>
thanks G!
Drizzo
Jan 16, 2006 03:31 PM
an2ny888
15
May 7, 2005 02:03 PM
roadawg
Dec 8, 2003 09:17 AM
Mike95lude
Aug 20, 2002 11:31 PM
Halive
22
Jun 28, 2002 02:33 PM
