metal clinking noise from the tranny
i have a noice coming from the clutch area ... it sould like metal clinking on another piece of metal ... but it only does it when u push the clutch in and if you let it go it does nothing its quiet does neone know what that could be?>
last time i heard that i took trans off to find a piece of the press plate had broke off. cheap ebay clutch ... happened 2 x ... then i went with act...
the springs on the pressure plate have stareted to break out of the housing if you're lucky. Drop the tranny and get it fixed before it turns into a more expensive problem, and good luck!
xhatchracerx
Nov 18, 2003 09:46 PM
