smoke coming out of valve cover breather
Old May 18, 2008 | 11:33 AM
ganjasnack's Avatar
Default smoke coming out of valve cover breather
i have a 95 lsvtec turbo setup, i have a crome chipped ecu that works fine, my vtec wasnt working before and now i have it working but when i start my car smoke comes out of my breather on my valve cover, and when i drive it my car smokes a lot out of the exhaust. i dont recognize the smell and it is like white to blue tinted smoke
Old May 18, 2008 | 12:08 PM
1fastlude1's Avatar
Default Re: smoke coming out of valve cover breather (ganjasnack)
the smoke from the breather is blow by, check ur compression, and do a leak down test, its normal to have blow bym but if its just idleing with a steady sream of smoke theres a problem
Old May 18, 2008 | 05:45 PM
DrivenMC's Avatar
Banned
yeah sounds like your rings are shot. Did you over heat your engine / or change types of oil?
Old May 20, 2008 | 01:56 PM
ganjasnack's Avatar
Default Re: smoke coming out of valve cover breather (DrivenMC)
no overheating or change in oil but i did do a compression test all the way around and cyls 1 2 and 4 had 184 PSI compression and cyl 3 had like 60, and when i put some oil in the cylinder it didnt change at all, to my understanding that means that its either the head gasket, valve seals or valves. I took my head off and the number 3 cyl is all black and oily, i think it is the seals.
Old May 20, 2008 | 02:02 PM
tricura's Avatar
If you have stock pistons you probably broke a piston between rings. That is pretty common especially in cyl#3.
Old May 20, 2008 | 02:07 PM
turbo-crx's Avatar
asounds like cracked ringland.
Old May 21, 2008 | 11:22 AM
hondaLovin's Avatar
Default Re: (turbo-crx)
sounds like your rings or ringlands are gone.
lunareg
Aug 22, 2010 03:31 PM
Redprelude98
30
Jul 21, 2009 01:21 PM
vtec.dc2
Jan 14, 2005 11:41 PM
00ITR #543
Jun 21, 2002 12:56 PM
Thats-so-Ls
Nov 12, 2001 12:12 AM
