Timing Belt Question
Old May 17, 2008 | 06:06 PM
jravensc's Avatar
Default Timing Belt Question
I did my timing belt this weekend. After we started the car I have a pretty noticable whine coming from that area. When we were putting the balance belt on the tightening sequence didn't seem to tighten the belt. we could still spin the tensioner without the belt moving. so we ended up applying hand pressure and then tightening the adjusting bolt.
now i'm wondering if we overtightened it.
the helms manual does have a secton about adjustment without a total breakdown, but it doesn't tell you to take off the lower cover, which means i can't put the 6mm bolt to hold the timing belt tensioner.
By the way this is a 99 accord EX 4 cylinder.
one last question. did honda make a 99 4 cylinder DOHC?
Old May 18, 2008 | 10:35 AM
hondadude's Avatar
Default Re: Timing Belt Question (jravensc)
hope you didnt leave the 6mm tension retaining bolt in there.
You can loosen the tension nut that is sticking thru the timing cover, then turn the crank 1/4 turn and retighten the tensioner nut.
The counterbalance belt doesn't need to be tight, it is driven by the cogs and belt teeth
Old May 18, 2008 | 01:01 PM
jravensc's Avatar
Default Re: Timing Belt Question (hondadude)
Thanks for the reply. No, we removed the 6mm and reused it in the lower cover.
That is great news. I really think we did overtighten the balance belt. It looked crazy loose but I guess it was correct.
Thanks again
ps
any word on that DOHC accord?
Old May 18, 2008 | 02:21 PM
MustangLX6.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jravensc &raquo;</TD></TR><TR><TD CLASS="quote">
any word on that DOHC accord?</TD></TR></TABLE>
no 99 DOHC accords were made. at least not in USA
Old May 18, 2008 | 09:35 PM
civiccoupe94's Avatar
did you overtighten or undertighten the alternator belt after you were finished?
Old May 19, 2008 | 04:52 AM
TouringAccord's Avatar
H-T Order of Merit
sorry I wasn't able to respond to your PM over the weekend as I was busy and did not make it online.
I did respond to your PM earlier though
Old May 19, 2008 | 01:03 PM
jravensc's Avatar
Default Re: Timing Belt Question (TouringAccord)
Hey civic, no the alt belt is o.k. The noise is definately coming from the inside the timing/balance belt region.
No worries Touring, I appreciate you taking the time to respond. I will try to make the adjustment soon and let you guys know if all is well.
Old May 19, 2008 | 04:28 PM
jravensc's Avatar
Good news, I did the adjustment and it fixed the problem. No more noise = no more me closing my eyes and rubbing my temples at every stop light. Thanks for your help guys.
Old May 20, 2008 | 03:50 AM
H-T Order of Merit
glad you got it fixed
marymiller29456
Classic Hondas
Oct 31, 2012 12:03 PM
WiedemannC
Dec 6, 2010 12:35 PM
mattatchison
Jun 7, 2007 04:58 PM
ranta18
Jul 9, 2003 12:41 PM
Luserkid
Apr 10, 2003 06:41 PM
