turbo civic will not start need help
Old May 17, 2008 | 08:17 AM
type-rcivicman's Avatar
Default turbo civic will not start need help
i have a ls vtec 84mm turbo civic sc61 hondata s200b that will not start i think its an issue with the fuel. checked compression read 200 on all four has fuel pressure 1000cc injectors that i had flow tested and they are fine changed the resitor box twice still will not start changed dizzy cap it has spark if we spray starting fulid in intake it will stay running dont know what else it can be tried different ecu also please help if you have any ideas...
Old May 17, 2008 | 09:29 AM
Glove's Avatar
Default Re: turbo civic will not start need help (type-rcivicman)
has it been tuned?
Old May 18, 2008 | 12:03 PM
1fastlude1's Avatar
if you can start it with starting fluid then either you have no fuel pressure or injector pulse or both, go from there
Old May 18, 2008 | 02:04 PM
Default Re: turbo civic will not start need help (1fastlude1)
yeah it was tuned just found out its the 3 bar map senson disconnected it and pluged the stock one in and it started didnt run good but it started so new map sensor is on the way
DuecedSol
Jun 15, 2012 07:28 AM
lvlrlvlopar
Aug 2, 2009 06:34 AM
brianfromhawaii
Jun 16, 2009 11:44 PM
808DB1
Aug 21, 2008 02:05 AM
Teglove2
Nov 8, 2004 03:52 PM
