Who ACTUALLY has the Hondata intake gasket ON their R?
Old Jul 14, 2002 | 11:30 PM
RagingAngel's Avatar
Default Who ACTUALLY has the Hondata intake gasket ON their R?
I bypassed the system a few days ago and much to my dismay the car does as Hondata said it would..
OVERHEAT.
The intake temps stay wonderfully cool, but you cannot drive the car in traffic without the temp slider all the way over to the HOT side.
Makes it nice during the summer huh?!
Hondata says to drill the thermostat.... I won't pretend to understand the cooling system of the Type-R let alone ANY car....but does anybody have any clue how to do this before I break out the drill and drill bits and attack my thermostat?
RA who is seriously regretting NOT cutting the gasket block off instead of running the bypass race setup for daily use....
Old Jul 14, 2002 | 11:34 PM
tonyxcom's Avatar
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (RagingAngel)
then why dont you cut the bypass whole out and rid yourself of the overheating problem.
Old Jul 14, 2002 | 11:35 PM
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (tonyxcom)
because I already butchered the hoses and going back to the original setup would require buying new hoses.....
I've gone this far so why not drill the damn thermostat too?
Old Jul 14, 2002 | 11:50 PM
sgT's Avatar
sgT
You didnt do what i TOLD YOU to do did you?!?!
Old Jul 14, 2002 | 11:58 PM
Batoutahell's Avatar
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (sgT)
Steve, I'd like to hear your opinion on how to install the hondata gasket. I've considered installing one to lower temps from my blower. Is it best to cut the hole in the gasket, or is there more to it than that?
Old Jul 15, 2002 | 12:32 AM
I dun recall you telling me anything!? Please repeat so all of us can benefit wise Sempai....~
EDIT: This is all I could find that you mentioned:
Also, its not coolant flow TO the head, its coolant flow FROM the head.
Coolant gets to the head from the block and exits the head to the radiator and
to the thermostat housing and heater core.
I'm trying to think of what I have to do.....and my brain....says......"No"
EDIT:
FOUND IT.... Brain still works marginally.....:
you do not have to drill the thermostat.
All you have to do it tee the heater line coming from the side of the head
to the port that the other line went to on the thermostat housing.
Now brain must visualize what wise Sempai is saying....and brain....says...."No"
[Modified by RagingAngel, 1:38 AM 7/15/2002]
[Modified by RagingAngel, 1:43 AM 7/15/2002]
Old Jul 15, 2002 | 12:54 AM
sgT's Avatar
sgT
Original line went from intake manifold to thermostat housing
Now, there is a heater hose coming out from the side of the cyl head that goes to
heater core. You cut that in the appropriate place, and put a "T" there.
From that T, run a line that goes to the port on the thermostat housing where the
old line(see the first line in this post) went to.
Old Jul 15, 2002 | 01:06 AM
So essentially what I did here was INCOMPLETE....or downright INCORRECT?
Old Jul 15, 2002 | 01:39 AM
Darkteg's Avatar
New User
i'm using hondata gasket street version and no problems at all with overheating. i also bypassed the TB and IACV valve. the manifold runs very cool.
Sgt, can u be more specific about the racing install? i didn't know how to do it so i cut the little square piece on the gasket.
Old Jul 15, 2002 | 02:03 AM
sgT's Avatar
sgT
incorrect.
you teed the WRONG HOSE.
Old Jul 15, 2002 | 02:04 AM
sgT's Avatar
sgT
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (Darkteg)
I dont know how much more specific I can be without pictures.
This isnt exactly rocket science.
Old Jul 15, 2002 | 02:53 AM
incorrect.
Yabaii!! CHO YABAII!!
I think Steve means the hose that is essentially right under the VTEC solenoid....
ARGHHHHHHH!!!
means it's off to Acura.... or some hose depot....
Old Jul 15, 2002 | 02:56 AM
gsr98vtec's Avatar
do it sgT's way. thats how i did it and it works. can i describe it for you, no sorry. i would just need to show you in pics. let me see if i can go snap a pic with the digicam of how its supposed to look for you.
Old Jul 15, 2002 | 03:03 AM
Darkteg's Avatar
New User
does anybody have pics?
where did ranging angel got wrong?! he teed the wrong line, so where's the correct one?!...
darkteg, who is taking a course on rocket engineering
Old Jul 15, 2002 | 03:05 AM
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (gsr98vtec)
gsr98vtec: It would be GREATLY appreciated if you could snap some pix.... I'm sitting here at 4am eyes watering thinking of what I can do since it's more than likely Acura won't have those hoses in stock at my dealership....
and thought of driving with the heat on makes my HAIR sweat.....
I got a 12hour drive in 2days....
Old Jul 15, 2002 | 03:13 AM
MackSpeed-616's Avatar
just take the t out of the hose you tapped and replace it with one with a straight metal pipe.
gsr 98vtec is right.. you tap the line from the thermo housing to the line that goes underneath the vtec solenoid
Old Jul 15, 2002 | 06:45 AM
rolow's Avatar
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (BustaNutt-616)
I am more confused then ever!
Old Jul 15, 2002 | 08:41 AM
sgT's Avatar
sgT
I dont get it.
I said Tee the heater hose that comes out of the side of the head, and you
guys dont know what im talking about?
Old Jul 15, 2002 | 08:44 AM
Johnny Tran's Avatar
I dont get it.
LMAO......where's this "head" thing at??
....stunnaz
Old Jul 15, 2002 | 09:59 AM
BenMara's Avatar
have yall read this post???
https://honda-tech.com/zerothread?id=132940
Old Jul 15, 2002 | 10:25 AM
sgT's Avatar
sgT
Default Re: Who ACTUALLY has the Hondata intake gasket ON their R? (BenMara)
OMG, its right there plain as day!
Old Jul 15, 2002 | 11:11 AM
stizzit's Avatar
Heater hose:
a.k.a: the one that goes to your HEATER core
a.k.a: the one that provides your heat that makes your hair sweat
a.k.a: just about the only one 1" (thereabouts) in dia on the dist side of the "head"
a.k.a: the little thinggy that is mounted to your firewall and has a little wire thing on it and a hosey thingy hooked on to it then goes to that thing called a head maybe a cylinder head.
have one on me ....
Old Jul 15, 2002 | 04:01 PM
Tommy_Gunns's Avatar
Few questions:
1. How much cooler will the engine run with this race setup vs just cutting the coolant block on the hondata gasket?
2. There are two heater hoses, the one we should tee is the long one located under the VTEC solenoid, right?
3. Do you plug the coolant line on the intake manifold now that it is no longer in use?
4. How good of a seal is the Hondata gasket (with the coolant block uncut) against coolant leaks? Anybody ever had it blow out on you?
Thanks.
Old Jul 16, 2002 | 03:23 AM
DutchITR1689's Avatar
You have already cut that piece, so you can't go back now to the racing setup.....
I don't the Hondata gasket but I have also bypassed the TB and IACV. Did you just connect the hose from the return pipe to the intake manifold?
Old Jul 16, 2002 | 05:05 AM
Darkteg's Avatar
New User
Sgt,
did u also take out the support bracket under the manifold, can i discard it?
how much of a difference in temp is from the street version to the race one? does it stay alot more cooler?
what about gains, personally i didn't notice anything after the instalation...
