Tranny Guru's - Question
Old May 15, 2008 | 09:09 PM
ExVtec's Avatar
Default Tranny Guru's - Question
Not sure how this happened, but after putting the tranny back together from a countershaft failure last fall and placing the case on the trannmission...I noticed it wasn't falling into place, had a 1/4" gap around..normally it falls into place, or with the help of a slight tap. (2nd rebuld after lsd install 2 yrs ago).
After careful inspection, I noticed the C clip/snap ring thingy that the countershaft bearing pops into on the trans casing was damaged. The inner lining that the ring lays in is all boogered up. I can order another c-clip snap ring whatever it's called, but the case is damaged on the inside...
Looks like unless I get another trans case 1/2 I won't be able to put the tranny back together.
How important is this little clip thing? It's the one that slides around the top of the bearing, bolt/top side of the countershaft.
Thanks in advance.
:cool:
Old May 16, 2008 | 09:43 AM
ExVtec's Avatar
Default Re: Tranny Guru's - Question (ExVtec)
Well I got another snap ring, gonna dremel the area where it goes, smooth it out a tad...get it back together..
Or @ least thats the plan....
Old May 16, 2008 | 05:30 PM
97grnrs's Avatar
thats what i did to one.. it seems ok .
socallmechris
Jun 19, 2008 09:10 AM
civicb16eg
Feb 2, 2007 07:29 AM
gsr18cx
Aug 27, 2004 01:24 PM
NitrousB.I.G.
Jul 16, 2004 05:00 AM
eg6h8k
Jun 21, 2003 12:30 PM
