skunk 2 intake manifold problem need help!!!!!!!!!!!
Old May 15, 2008 | 07:15 PM
mesonerz's Avatar
Default skunk 2 intake manifold problem need help!!!!!!!!!!!
well i put on a skunk 2 intake manifold today on my 94 gsr and im having some serious idle problems. the idle revs high at 1000 rpm then revs to 2500 rpm and then drops down to 1000 rpm and repeats this. there is no c.e.l unless i unplug the map sensor. any help would be greatly appreciated.
Old May 15, 2008 | 07:34 PM
mesonerz's Avatar
Default Re: skunk 2 intake manifold problem need help!!!!!!!!!!! (mesonerz)
Old May 15, 2008 | 07:43 PM
wunfstgsr's Avatar
Loved
Community Favorite
On the throtle body there is a flat head screw turn it a little bit at a time untill your idle drops around 8-900 rpms worked for me when i had the same prob.
Old May 15, 2008 | 09:19 PM
all-mtr-teg's Avatar
Reversed the TPS and MAP sensor plugs by accident?
Old May 16, 2008 | 04:04 AM
polishedturd's Avatar
I like PIE
Default Re: skunk 2 intake manifold problem need help!!!!!!!!!!! (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Reversed the TPS and MAP sensor plugs by accident?</TD></TR></TABLE>
x2
or you did not clean the gasket off of the head and/or throttle body completely and you have a vacuum leak.&lt;-----ive done this before.
Old May 16, 2008 | 10:45 AM
mesonerz's Avatar
Default Re: skunk 2 intake manifold problem need help!!!!!!!!!!! (polishedturd)
ill definitely check the plugs to make sure there not reversed...i did a good job of cleaning off the gasket but you never know. if the tps and map plugs arent reversed ill check that second. thanks for the information
Old May 16, 2008 | 01:37 PM
J. Funk's Avatar
vacuum leak. It happened to me
Old May 16, 2008 | 04:41 PM
mesonerz's Avatar
Default Re: (J. Funk)
yeah its gotta be a vacuum leak. the tps and map plugs are definitely correct. now i just have to locate the source of the leak. someone was saying that the i.a.c valve might be the problem. tomorrow is a new day of trouble shooting
Old May 16, 2008 | 10:23 PM
dc2_916's Avatar
Default Re: (mesonerz)
chekk the pcv hoes.. i didnt have a clamp on mines and it did the same thing.. idle like crazy and i had cams
Old May 16, 2008 | 10:31 PM
Start spraying down the IM gasket and throttle body gasket areas with carb cleaner to locate the leak. I once had a bolt on the bottom in the center that wasn't torqued properly cause a leak.
Old May 17, 2008 | 09:47 AM
mesonerz's Avatar
ok well i got rid of the idle fluctuation. now it just idles at a steady 1500 rpm. HELP!!!!!!!!!!!!!
Old May 17, 2008 | 06:01 PM
mesonerz's Avatar
my car idled perfect before the skunk 2 went on. at least now i got rid of the idle fluctuation but it still idles at a steady 1500 rpm. me and my friend cleaned the f.i.c.v and played with the little idle screw. maybe there is something we are over looking. i dont know. any help please. and yes i did a search but nothing very useful or anything that i haven't tried already. HELP!!!!!!!11
Old May 17, 2008 | 06:02 PM
Dogginator's Avatar
Daisy... Daisy...
You probably have a vacuum leak or a throttle body that is not closing.
You will notice in your TB throat that there are three holes. They are for the idle screw, the IACV, and the FITV (OBD1). You can determine if you have a vacuum leak by removing the air intake and blocking those three holes. If the car keeps running, air is entering via a leak.
Old May 19, 2008 | 02:15 PM
mesonerz's Avatar
well i figure id let everybody know that i fixed my idle problem. the culprit was a vacuum due to the throttle body gasket. the throttle body gasket i received was for a obd2 car. i replaced it with a obd1 gasket and now its golden.
Old May 20, 2008 | 03:21 AM
I like PIE
cool, glad to hear it
Old May 21, 2008 | 01:11 PM
mos820def's Avatar
Nice and easy fix. I've got the same IM.
99ek4Dr
10
Mar 2, 2011 06:22 PM
krucial7integra
22
May 15, 2008 11:26 AM
mutantmopar
Aug 2, 2007 03:06 PM
FERIOkid
Nov 11, 2006 04:07 PM
pnltnc
Honda S2000
Oct 16, 2006 02:37 PM
