b16 turbo basemap
Old May 15, 2008 | 06:00 PM
pokmijn's Avatar
Default b16 turbo basemap
i was just wondering will my car be ok to drive from freso to sac with a basemap for my setup. the reason driving that far is because im getting it tuned there.
Old May 15, 2008 | 06:03 PM
vladd's Avatar
Default Re: b16 turbo basemap (pokmijn)
don't rev it higher than you have to and you'll be ok.
Old May 15, 2008 | 06:52 PM
Jimmy's Avatar
Global Moderator
It really all depends on the basemap your running..
How much boost r u running right now?
What is your timing set at?
Do you have a wideband?
How far of a drive is it?
You most def do not want it to lean out on a far drive.
Old May 15, 2008 | 07:05 PM
vladd's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">It really all depends on the basemap your running..
You most def do not want it to lean out on a far drive.</TD></TR></TABLE>
basemaps are generally really rich, so no worries about running lean. the idea of a basemap is to get you to your tuner without blowing up your engine, not to extract the max hp out of your engine, so max boost and timing don't come into play. you're not supposed to redline your engine on a basemap.
Old May 15, 2008 | 07:09 PM
Jimmy's Avatar
Global Moderator
Default Re: (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">
basemaps are generally really rich, so no worries about running lean. the idea of a basemap is to get you to your tuner without blowing up your engine, not to extract the max hp out of your engine, so max boost and timing don't come into play. you're not supposed to redline your engine on a basemap.</TD></TR></TABLE>
Right.. Well the OP hasn't really gave us much info on his setup.
When i hear basemap.. I'm thinking ebay chip.. hopefully it is a decent map.
Old May 15, 2008 | 07:31 PM
vladd's Avatar
Default Re: (Jimmy)
When i hear basemap.. I'm thinking ebay chip.. hopefully it is a decent map. </TD></TR></TABLE>
a basemap is generally referred to what the guy who puts the chip/socket in burns in for you, not to an ebay chip. an ebay chip is not the same thing as putting in a chip/socket for tuning. i drove for a few hundred miles with my basemap while troubleshooting various problems without any problems, even with numerous trips to the redline
Old May 17, 2008 | 02:45 AM
pokmijn's Avatar
Default Re: (vladd)
alrite thx guys will i will only be runnin gon 8 psi it would be like a 2 hours 30 min drive and no it not a ebay chip its a custom base map for my setup.
Old May 17, 2008 | 05:54 AM
mn_babyboy's Avatar
Default Re: (pokmijn)
just stay below the where the turbo spools. under 3,000rpm it should still be in vacuum.
SO in those part of the maps, it should be safe.
So even if you have a basmap, before boost kicks in, it should still be safe. Just drive speed limit and it should be safe.
CivSiClone_96
Sep 14, 2009 09:59 PM
batboyvaj
Apr 10, 2005 07:39 PM
Flr Power
Dec 19, 2004 10:44 PM
honda9369
Sep 22, 2004 03:45 PM
psychotic_z
Nov 21, 2003 10:40 PM
