oil feed line block adapter option!
Old May 15, 2008 | 04:56 PM
chimmike's Avatar
Default oil feed line block adapter option!
since I've noticed that honda too uses a 1/8" BSPT fitting for the oil sender in the block, I used to use this on my nissan turbo cars:
http://www.nissport.com/catalo...tions
I figure this sucker will work perfectly on the hondas too! Any reasons why it possibly wouldn't?
Old May 15, 2008 | 06:07 PM
inspyral's Avatar
If there's enough clearance for it, there's no reason why it wouldn't work for Hondas. The only concern I can see is that it seems a bit bulky and might result in a cranked oil pressure port if you try to attach too much weight to it. Also, it's $50
Old May 15, 2008 | 06:18 PM
chimmike's Avatar
Default Re: (inspyral)
I've used it in 3 other nissans, it's not as bulky as the pics looks. As for too much weight, it's aluminum
Old May 16, 2008 | 04:57 AM
Tigre Tuning's Avatar
i think he meant to say the weight you would attach to the adapter not the adapters weight itself. and someone actually already sells the same thing for honda's either way. and we have a 1/8 Bspt thread not a true pipe thread just like a nissan
Old May 16, 2008 | 05:25 AM
chimmike's Avatar
Default Re: (Tigre Tuning)
who sells the item for hondas? I'd be interested in checking it out. As for if this would work well or not, I'm sure it'd work just fine and weight wouldnt' be an issue.
Old May 16, 2008 | 06:04 AM
shortyz21's Avatar
Default Re: (chimmike)
why would they make it outta SS...
Old May 16, 2008 | 06:20 AM
chimmike's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">why would they make it outta SS...
huh????
Old May 16, 2008 | 06:30 AM
mike93eh2's Avatar
$20
http://www.stealthmodeperforma...shtml
Old May 16, 2008 | 06:36 AM
chimmike's Avatar
Default Re: (mike93eh2)
Thanks!
the only reason I guess one might go with the nissport adapter is the ability to run oil pressure/oil temp gauges off the adapter as well as the oil sender and feed line.
I like that stealthmode fitting though. I think i'll be picking one of those up.
Old May 16, 2008 | 06:40 AM
chimmike's Avatar
has anyone used the stealthmode oil restrictor? I'm kinda questioning how it'll work if, say, someone doesn't know how much to adjust it for their particular turbo!
Old May 16, 2008 | 06:45 AM
accord99power's Avatar
Default Re: oil feed line block adapter option! (chimmike)
I am a turbo newbie, my kit didnt come with this adapter, im planning on running 7-8 pounds of boost do i need this oil adpater and why? also where do i run the line to if i do need this? any help would be awesome!
Old May 16, 2008 | 07:50 AM
chimmike's Avatar
Default Re: oil feed line block adapter option! (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">I am a turbo newbie, my kit didnt come with this adapter, im planning on running 7-8 pounds of boost do i need this oil adpater and why? also where do i run the line to if i do need this? any help would be awesome! </TD></TR></TABLE>
I recommend you reading the FAQ's so as to not lose topic on this thread
Old May 16, 2008 | 09:42 AM
AspectIndustries's Avatar
Read the Link dude. It clearly states Stainless Steel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">I've used it in 3 other nissans, it's not as bulky as the pics looks. As for too much weight, it's aluminum </TD></TR></TABLE>
Old May 16, 2008 | 10:25 AM
chimmike's Avatar
Default Re: (AspectIndustries)
that's new to me then, the last 3 I owned were all aluminum.
chrisbell37
Feb 3, 2006 06:36 AM
Tad
Jan 2, 2006 03:15 PM
b00sted_GS-R
Jun 17, 2004 05:29 PM
zbower7
May 14, 2004 01:42 PM
GSR x13
Dec 1, 2003 10:52 PM
