help installing
Old Jun 16, 2004 | 11:59 PM
b00sted_GS-R's Avatar
Default help installing
need help installing a oil pressure sender for the autometer guage. installing this on a gsr.
Old Jun 17, 2004 | 05:11 PM
Garcia-Racing's Avatar
Default Re: help installing (b00sted_GS-R)
I run a -3 steel braided line from the back of the block, eliminating the stock oil pr. sensor. run it to a brass tee, mounted on the firewall to relieve the weight of unit off of the block. The oil pr. sending unit goes in the next port and the oil feed for the turbo into the last. Be sure to ground the sending unit
Old Jun 17, 2004 | 05:29 PM
B18C1CYA's Avatar
Default Re: help installing (TGARCIARACING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGARCIARACING &raquo;</TD></TR><TR><TD CLASS="quote">I run a -3 steel braided line from the back of the block, eliminating the stock oil pr. sensor. run it to a brass tee, mounted on the firewall to relieve the weight of unit off of the block. The oil pr. sending unit goes in the next port and the oil feed for the turbo into the last. Be sure to ground the sending unit </TD></TR></TABLE> couldnt say it better just be shure you have a bspt adapter for the block
B R Fittings
Dec 2, 2011 06:28 PM
totsie7944
May 1, 2008 04:52 AM
chrisbell37
Feb 3, 2006 06:36 AM
zbower7
May 14, 2004 01:42 PM
slingshotsi
Sep 9, 2001 06:11 PM
