k20a2 runs rich in cylinder #4
I just swapped a k20a2 into my car two weekends ago. Everything went fine, had the fluctuating idle but that went away in a couple days. It pulled hard and I thought everything was perfect. A day or two after that, it started misfiring. Replaced the plugs with Denso Iridiums and no difference, CEL came on in a couple minutes.
Cylinder #4 (I think it's #4 - it's nearest to the tranny) was completely carbon fouled within 100 miles on the plug. Plug IS sparking. I tried a new plug in that cylinder and it was carbon fouled after a couple minutes of idling. Swapped injectors with a k20a3 injector, still no power. I put the a2 injector back in and gave up - it was 2am.
So it seems to be getting spark and gas but cylinder #4 is running rich. I have a SRI and full exhaust. What could this be? (I can't afford to get it tuned right now)
I'm going to do a compression test but I doubt that cylinder has low compression because the motor was pulling hard for a few hundreds miles.
I did the compression test. Please note that I used a $15 compression tester I just bought from Harbor Freight and this is my first time doing the test alone. I tried letting each cylinder crank 5 times but I can't be certain since I didn't have anyone watching the needle jump.
(Pulleys side) - 165 - 165 - 160 - 160 (tranny side)
I bolded the cylinder that is fouling plugs.
Here is the plug (has about 60 miles on it since I cleaned it last. About 250 total miles on it):
Well, autozone's crap scanner said it misfires in all the cylinders, Acura said it was only that cylinder (4) and 10 minutes later said it's #1, 2, and 4.
This cylinder is misfiring for sure, but I think it's the only one misfiring. I mean, it still has power, more than the a3 and this is the only plug that looks bad at all. I swapped coils before and it didn't change a thing. :s
Calvinator
Jul 21, 2006 02:29 AM
