Am I missing anything?
I am doing quite a bit of maintenance to the ITR before expo.....My stock 97 is 11 years old now, and I wanted to make sure that she is up for the hpde speeds and possible stresses of being on track....
So far, I am going to change the following.....If I am missing something please chime in w/ any suggestions.....
Car has 137k on the odo...
-New Koni Yellows w/ stock springs( I feel like the oe shocks are on their way out)
-spark plugs
-oil filter/oil
-tranny fluid
-magnetic drain bolts
-Techna Fit ss brake lines/new fluid
-K&N drop in air filter
-fuel filter
-timing belt/water pump etc. was done less than 10k miles ago
-new cap,rotor,coil was replaced @ 5k miles ago
-tires are 205/50 azenis w/ about 4k miles
I am going to run the stock pads/rotors at expo and then replace them w/ o.e. when I get back home....
-spark plugs
-oil filter/oil
-tranny fluid
-fuel filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">Go ahead and get your replacement rotors/pads and bring them with you to Expo
I agree and I would recommend ordering small parts to keep it on hand. But that's just me though. For instance spare plugs, spare pads, spare valve cover studs and nuts, spare valve cover gasket. I have seen instances last year where someone needed a valvecover stud because they stripped theirs. I'd hate to miss out on driving because of something little like that.
</TD></TR></TABLE>I agree and I would recommend ordering small parts to keep it on hand. But that's just me though. For instance spare plugs, spare pads, spare valve cover studs and nuts, spare valve cover gasket. I have seen instances last year where someone needed a valvecover stud because they stripped theirs. I'd hate to miss out on driving because of something little like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Good advice and bring a bunch of zip-ties too. Oh, don't forget to call Len to order those parts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eksteve »</TD></TR><TR><TD CLASS="quote">Torque wrench, air pressure gauge....?
and
Fat shoes for heel-toe downshift
If you have a small foot of course
What's the deal with the shoe regulations? It says leather or leather type material? Can't we just use regular closed toe shoes? I don't want to be turned away from driving because of something stupid so i'd like this cleared up
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ultraspeed DC2 »</TD></TR><TR><TD CLASS="quote">
What's the deal with the shoe regulations? It says leather or leather type material? Can't we just use regular closed toe shoes? I don't want to be turned away from driving because of something stupid so i'd like this cleared up</TD></TR></TABLE>
Where did you read that? I wore my Airwalks last year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">
Where did you read that? I wore my Airwalks last year.</TD></TR></TABLE>
In the Expo 8 Rules & Regulations quote under Required Equipment:
"-Non-synthetic fabric clothing (i/e/ Cotton), including long trousers, socks and a long-sleeved shirt.
-Shoes must be closed and of a flexible solid leather or imitation leather construction."
yes, I was like wtf?
just curious as to why?
do you think I will wear them down so much it will not be safe to drive back to ILM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Hoses in good shape?
that is a good question.... they look fine, no cracking/fraying.....Is there something else I should be looking for?
and
check
Thanks for all the input so far
</TD></TR></TABLE>just curious as to why?
and
check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 »</TD></TR><TR><TD CLASS="quote">
well if you are replacing them when you get back from expo, you might as well order them now, and bring them. just in case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1235 »</TD></TR><TR><TD CLASS="quote">new shifter bushing, green automotive painters tape,</TD></TR></TABLE>
I actually have the shifter bushing ordered too.....
I just did not feel like it was worth listing since the oe are fine.... I just prefer the feel of the ES bushing....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">uhhg. I HATED the ES shifter bushings. I missed gears so many times because of them. I switched back to stock and it doesnt feel nearly as notchy. </TD></TR></TABLE>
i did the same exact thing.
I've seen people destroy a set of pads, especially stock, in a day. Of course that all depends on the driver, but better safe than sorry, or better yet drinky-time on Monday afternoon instead racing to Autozone for spares
blue1.6eg
Apr 18, 2015 01:34 PM
Convert
13
Feb 28, 2008 12:17 PM
alacard
Jul 12, 2005 02:20 PM
