Maintenance: Take a look and see if i got everthing
Trying to make a list of things i need to do, and just looking for a little input
edit: the chasis is at 135k, motor is JDM so...60k? Im going to seafoam to keep her clean, but past that, i have no idea what the car has done or not, about to put mobile one in and see what happens.
New thermostat/ flush and fill on coolant
tranny fluid change
oil change (duh)
brakes f/r rotors and pads
p.s. since winter has been on, my car has had a terrible time warming up. im assuming that the t-stat is stuck open which would be the big reason why it wont warm up even after a 20 min drive. any input is greatly appreciated!
THANKS ALL!!!
Modified by Convert at 11:22 AM 2/28/2008
tranny fluid change
oil change (duh)
THANKS ALL!!!
Re: Maintenance: Take a look and see if i got everthing (Convert)
inspect brake lines make sure no leaks? like another guy said water pump and timing belt?
Re: (4do4damsho)
oil filter=check
plugs=recently changed
cap/rotor=no clue
brake fluid=needed
fuel filter=needed
grounds=needed
thermo=see below
pcv valve=needed im sure
tranny flush=needed
coolant flush=bad needed
spark plug wires=new
yeahm the thermo si still puzzling me. anyone else on this? like i said, the main problem is the fact that the car isnt warm even after a 20 min drive.
thanks!!!
cap/rotor=no clue
brake fluid=needed
fuel filter=needed
grounds=needed
thermo=see below
tranny flush=needed
thanks!!!
Re: (mortificationrock)
well, after taling with my mech, he surmised that maybe some jackass had removed the water pump altogether. at any rate.
thanks again all!
thanks again all!
Resident Gearhead
Re: (Convert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convert »</TD></TR><TR><TD CLASS="quote">well, after taling with my mech, he surmised that maybe some jackass had removed the water pump altogether. at any rate.
thanks again all!</TD></TR></TABLE>
No, (s)he is wrong. The water pump is driven by the timing belt.
Resident Gearhead
Re: (Convert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convert »</TD></TR><TR><TD CLASS="quote">actually ima douche. i meant thermostat.
way to look like a jackass. thats what i get for working and <FONT COLOR="red">looking at H-T</FONT>
No big deal. What did you mean by that (in red)?
Re: (mcvtec)
meaning trying to concetrate on 2 things at once. im a photographer and i had a million people trying to talk to me while posting that, so i got a wee bit confused
