Car not starting after conversion
Old May 15, 2008 | 01:19 AM
R883's Avatar
Default Car not starting after conversion
Hi
I have just put a D16Y8 in my EK3 (1997) used to have a D15Z6 ( It is a UK car )
The problem i am having is that it is not starting
Turning over but not even trying to start
I am getting a CEL so i pulled to codes last night and got a
41 - Primary oxygen sensor - heater
I had to extend the wire for my o2 sensor but the wiring is fine.
It is only 1 wire though, should the y8 have a 4 wire sensor ?
Would this cause the engine not to start though
because from what i have read about other people having this problem, there car was still running
Another thing is the vacuum hoses, The y8 has a skunk 2 mani on it and the connections where totally different from mine.
I am 99% sure i have everything in the right place
But maybe not, would this cause the car not to start ?
Does anyone have any photos showing the vacuum connections on a skunk 2 mani ???
Cheers for any help
Old May 15, 2008 | 04:26 AM
R883's Avatar
Default Re: Car not starting after conversion (R883)
Can no one help ?
Old May 15, 2008 | 05:04 AM
sql_civic's Avatar
What ECU are you using with the Y8? Did you swap that?
Normally a Y8 uses a 4 wire O2 sensor. So your code 41 means that 2 of these wires are shorted.
Check your main ground that bolts up to the thermostat housing. Clean the contacts and make sure the connection is tight. A bad ground here will cause the symptoms you're having. Good luck.
Old May 19, 2008 | 01:50 AM
R883's Avatar
Default Re: Car not starting after conversion (sql_civic)
i dont have an earth at the thermo
dont think the y8 has one
well if it is meant to then thats my problem !!!
Old May 20, 2008 | 03:53 AM
R883's Avatar
ok i take that back
Cleaned up the thermostat ground but still no joy
checked all the fuses but they are fine
i really think it is some thing to do with my vacuum lines
still trying to find a good diagram showing me how to connect them
Old Jun 6, 2008 | 02:03 AM
R883's Avatar
Got the car running !!!!!!
Changed my ECU over to my old one
and it started straight away !!
So must be the imob, going to have to get a key with a chip in it as i dont have one.
Is it okay to run it with my old ECU ( P2Y ) ???
Does the fact it is for a v-tec e engine make any difference ?
It aint running great but i am putting that down to the wrong ECU
Any way cheers for everyones help !!!!
enzo1200
Apr 6, 2015 03:29 PM
benscivic22
Apr 5, 2015 05:11 PM
edwardjo86
Nov 19, 2012 07:31 PM
Dee_333
May 20, 2011 03:20 PM
WildPig
13
Jun 4, 2005 12:04 PM
