HORRIBLE emissions failure 50GPM limit of 15.00 CO2 and HC 5.9 to 1.2 limit
HORRIBLE emissions failure 50GPM limit of 15.00 CO and HC 5.9 to 1.2 limit
1995 Acura Integra LS
Hmm could it be the catalytic converter and my 02 sensor?
Setup is:
B16A OBD-1
8.1:1 JE Pistons
Crower valve retainers/springs
Maybe because I have a turbo built motor with no turbo and catalytic converter + 02 problems?
Any suggestions? Please help fast!
Setup is:
B16A OBD-1
8.1:1 JE Pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kr0n1k »</TD></TR><TR><TD CLASS="quote">Someone got an idea ? Please help I only have one day left on my temp tag
If you are tuned correctly, you should have no issues with the sniffer, regardless of whether or not you have a cat.
However, since you lack the cat, how do you expect any unburned fuel (or NOx) to not trip the sniffer? Throw a cat on that car, the environment will thank you, and a good one won't effect power enough to warrant running a street car without one.
</TD></TR></TABLE>If you are tuned correctly, you should have no issues with the sniffer, regardless of whether or not you have a cat.
mintscorpion
19
Jan 20, 2006 04:27 PM
aalb1
33
Aug 21, 2005 02:15 PM
