Bogs down
Old May 13, 2008 | 11:41 AM
x91crxsix's Avatar
Default Bogs down
got a 89 civic dx 1.5 dual point, the car will bog down then kick in and keep doin that , sometimes it wont do it for like 5 minutes and then it will start it again.sometimes the check engine will pop on and then it will completely bog down. throwin an 02 sensor code but i dont think thats the problem. hasnt died yet it will just bog if u go around a corner in 1st or 2nd and if u put it to the floor, its almost liek the throttle has to be in a certain spot for it to run decent. someone help, thanks
Old May 13, 2008 | 01:05 PM
kay@neighborhoodtrends's Avatar
Default Re: Bogs down (x91crxsix)
sounds stupid but.....
It could be getting to much fuel / dumping fuel
This can be caused by a bad injector or.. There is a rubber o-ring on the injector
were it meets into the TB it could be torn /worn out
Good luck
K
Old May 14, 2008 | 08:05 AM
x91crxsix's Avatar
Default Re: Bogs down (kay@neighborhoodtrends)
more help
Old May 14, 2008 | 04:32 PM
x91crxsix's Avatar
to the top come on guys gotta get this terd fixed this is my dd
Old May 14, 2008 | 04:36 PM
fin781's Avatar
or it could be the o2 sensor
Old May 15, 2008 | 12:04 PM
x91crxsix's Avatar
Default Re: Bogs down (fin781)
jsut replaced the o2 sensor and that didnt help, anymore ideas what i can try
Old May 15, 2008 | 06:00 PM
grog's Avatar
fuel filter, spark plugs/wires, timing, ect.
is you CEL still on?
Old May 20, 2008 | 09:04 AM
x91crxsix's Avatar
Default Re: Bogs down (grog)
nope the check engine is off now, put new plugs in it, the wires are fine, i jsut bought it like 2 weeks ago, maybe the gas is really old or somethin, ill throw in a fuel filter and it might have jumped time so i will check that also, thanks
eskimo10
Jul 21, 2009 07:45 PM
nudvl
Jul 23, 2005 11:14 AM
MidwestSi
Jun 23, 2005 05:43 AM
coupey
Aug 19, 2004 03:13 AM
BoostedGSRBubble
Mar 24, 2003 08:46 AM
