ecu help *pics
Old May 13, 2008 | 06:26 AM
zdizzle's Avatar
Default ecu help *pics
Its a b16 wth a p30, is this an obd1 or obd2, piggybacked i need some help. also wassup wth all the cut wires this is ecu is very sentive to toucth. Please help i want to fix this
here is another
more
[IMG]http://img.photobucket.com/albums/v488/zdizzle/PICT3242.jpg[/IMG}
thanx n advance
Old May 13, 2008 | 08:00 AM
Agnom's Avatar
Default Re: ecu help *pics (zdizzle)
Looks like OBD2 to OBD1 jumper harness, do you have check engine light on? How's the car run?
Old May 13, 2008 | 11:55 AM
zdizzle's Avatar
Default Re: ecu help *pics (Agnom)
yea its a cel on after it warms up it runs good but def could run better
Old May 14, 2008 | 04:17 AM
mmuller's Avatar
Mad Scientist
jeezz wow.
wire emi is a bitch
check grounds and if when you move the ecu changes the way teh car runs check map ground and main sensors ground ( iat,ect, tps, o2) which all have a common ground
Old May 16, 2008 | 04:58 PM
zdizzle's Avatar
Default Re: ecu help *pics (mmuller)
thanx man any idea were they might be on 96 civic cx candaian
Old May 17, 2008 | 04:43 AM
GhostAccord's Avatar
Are you familiar with the pin outs for an OBD1 ECU? You will need to know the wiring between both OBD1 & 2.
Here are the wires that you should be checking to ensure that they have solid contact. (Remember Every single wire on the harness should have solid contact)
OBD1 ECU Pin numbers
A26 = Primary Logic Ground (LG1 Ground for ECU Control Circuit)
A23 = Primary Power Ground (PG1 Ground for ECU Power Circuit)
A25 = Primary Power Source (IGP1 Power for ECU Control Circuit)
B02 = Secondary Logic Ground (LG2 Ground for ECU Control Circuit)
A24 = Secondary Power Ground (PG2 Ground for ECU Power Circuit)
B01 = Secondary Power Source (IGP2 Power for ECU Control Circuit)
D21 = Primary Sensor Ground (SG1 Sensor Ground MAP Sensor)
D22 = Secondary Sensor Ground (SG2 Sensor Ground ECT, IAT, TPS, etc..)
OBD1 ECU pins from the wire side of the ECU
* NOTE OBD1 pins are numbered left to right odd numbers on top, even on the bottom.
OBD2 wires coming off the conversion harness going out to the car
A09 = Primary Logic Ground (LG1 Ground for ECU Control Circuit)
A10 = Primary Power Ground (PG1 Ground for ECU Power Circuit)
A11 = Primary Power Source (IGP1 Power for ECU Control Circuit)
A22 = Secondary Logic Ground (LG2 Ground for ECU Control Circuit)
A23 = Secondary Power Ground (PG2 Ground for ECU Power Circuit)
A24 = Secondary Power Source (IGP2 Power for ECU Control Circuit)
D12 = Primary Sensor Ground (SG1 Sensor Ground MAP Sensor)
D11 = Secondary Sensor Ground (SG2 Sensor Ground ECT, IAT, TPS, etc..)
OBD2 conversion harness connector from the wire side.
* NOTE OBD2 pins are not numbered the same as the OBD1 Pins. They are numbered from left to right top to bottom.
A connector numbering;
1 2 3 4 | 5 6 7 | 8 9 10 11
12 13 14 15 16 17 18 19 20 21 22 23 24
| | 25 26 27 | 28 29 30 31 | 32
Modified by GhostAccord at 7:48 AM 5/18/2008
Old May 18, 2008 | 02:40 AM
Ovrbst_T66's Avatar
Damn rats nest.If you lived close to me i could fix it like new.find someone thats good with wiring and have them fix it for you.
Old May 18, 2008 | 05:59 AM
Acidcrakker's Avatar
Default Re: ecu help *pics (Ovrbst_T66)
Damn thats a hack job and a half. Good luck sorting that out. What codes are you throwning anyway?
Mattcuzko
Engine Management and Tuning
Mar 12, 2011 11:12 PM
honda305
Jan 7, 2009 08:37 PM
CeeJayy
Jul 27, 2007 07:48 PM
Under_Pressure
Mar 26, 2006 07:34 PM
SCsol
Oct 7, 2005 05:35 AM
