Questions for my crx
Old May 13, 2008 | 12:47 AM
dislazyboi's Avatar
Default Questions for my crx
I was Wondering if any would know why my car sometimes pull n tug at a steady pace/rpm?
Old May 13, 2008 | 06:16 AM
CW-ITR's Avatar
Default Re: Questions for my crx (dislazyboi)
It could be alots of things. To weave out the "alots of things", do the basic tune-up: Spark plugs, spark wires, air filter, timing.....Make note of the condition such as it improve or such and report back here. Hope that help.
Old May 13, 2008 | 06:25 AM
grog's Avatar
how is your idle?
I have had the FITV and IACV go bad and cause some bucking.
Old May 13, 2008 | 05:35 PM
dislazyboi's Avatar
Default Re: Questions for my crx (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">how is your idle?
I have had the FITV and IACV go bad and cause some bucking.</TD></TR></TABLE>
my idle goes up n down after a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">It could be alots of things. To weave out the "alots of things", do the basic tune-up: Spark plugs, spark wires, air filter, timing.....Make note of the condition such as it improve or such and report back here. Hope that help.</TD></TR></TABLE>
ok i will do
If anyone else got some ideas that they think will help please go ahead n share your thoughts thanks
Old May 13, 2008 | 07:18 PM
jtmoney2002's Avatar
Make sure ur getting constant fuel pressure, maybe be clogged fuel filter , dieing fuel pump ,maybe fuel pressure regulator?. But it can alwayz be a vacuum line,, throwing any codes? hope this helps
Old May 13, 2008 | 08:22 PM
dislazyboi's Avatar
Default Re: Questions for my crx (jtmoney2002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtmoney2002 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure ur getting constant fuel pressure, maybe be clogged fuel filter , dieing fuel pump ,maybe fuel pressure regulator?. But it can alwayz be a vacuum line,, throwing any codes? hope this helps</TD></TR></TABLE>
no codes no check light i just had the codes that were on fixed
and thanks i will be checking the fuel pump
Old May 13, 2008 | 10:08 PM
DCFerris's Avatar
mine dose this as well on a long road trip and then when i goto step on it, it lags i just turn my key off and then turn the car back on while on the highway and it's normal again
Old May 15, 2008 | 10:54 PM
dislazyboi's Avatar
Default Re: (DCFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFerris &raquo;</TD></TR><TR><TD CLASS="quote">mine dose this as well on a long road trip and then when i goto step on it, it lags i just turn my key off and then turn the car back on while on the highway and it's normal again</TD></TR></TABLE>
yea imma check it soon cause today it did it and died on the highway
thestorysritehur
Mar 11, 2008 08:34 PM
Takymoto
Feb 18, 2007 11:33 AM
kito858
Honda S2000
Nov 14, 2006 07:07 AM
Touge Tuning
Jun 23, 2005 05:21 PM
Thanks knightsport!
Apr 9, 2005 02:50 PM
