Honda S2000 Honda S2000
idle problem
Old Nov 13, 2006 | 05:53 PM
kito858's Avatar
Default idle problem
I don't know if its a problem, but im just curious if anyone else is in the same situation but when I rev bout 3000 or 4000 rpm, and let it drop, it almost idle 500 to 400 for like 3 seconds that it sounds like it was going to turn off but pulls back up to 1000. is there something wrong with my idle?? Thanks for the help!!!
Old Nov 13, 2006 | 06:04 PM
Dave_B's Avatar
Somewhat similar but not reved as high and I just ended up changing the plugs and now all is well.
Old Nov 13, 2006 | 06:17 PM
kito858's Avatar
Default Re: (Dave_B)
spark plugs? or wires?
Old Nov 13, 2006 | 08:39 PM
evil vapor's Avatar
Default Re: (kito858)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kito858 &raquo;</TD></TR><TR><TD CLASS="quote">spark plugs? or wires?</TD></TR></TABLE>
no. It can be normal in hot conditions or if the engine is heat soaked. Try tapping the map sensor a bit, located on the top of the throttle body.
Old Nov 14, 2006 | 07:07 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">
Try tapping the map sensor a bit, located on the top of the throttle body. </TD></TR></TABLE>
Search HT or S2ki "MAP Whack". Then reset your ECU.
dislazyboi
May 15, 2008 10:54 PM
GSR4U2NV
May 25, 2006 09:02 PM
N1ghtM0nkey
Mar 26, 2006 05:45 PM
knight_ryder00
Feb 17, 2005 10:35 AM
decipher_this
Jun 24, 2004 08:46 AM
