arp head studs on lsv
Wondering if anyone knows the torque spec on arp head studs? Also should I use locktite on the threads that go into the block? And can I resue them?
it depends on what motor you are using studs in, and do not use loctite, they come with moly lube.clean the threads before putting the lube on them.try visiting there website to find a spec http://www.arp-bolts.com/
