How do I know when to increase the Fuel Delivery?
Old Jul 14, 2002 | 04:02 PM
hondacivic4g's Avatar
Default How do I know when to increase the Fuel Delivery?
I have a 89 SI hatch. I'm swapping out the intake, intake manifold and Throttle body. In there place I'm adding a cold air intake, a D16Y8 intake manifold and a B-series Throttle body. Since I'm increasing my air intake volume ,can i, or should I increase my fuel delivery?
Thanks
Old Jul 14, 2002 | 04:12 PM
crx(gator)'s Avatar
Default Re: How do I know when to increase the Fuel Delivery? (hondacivic4g)
im kinda doing the same thing as you, but im using a d16z6 manifold and a b18a t-body, but i want to port match the manifold to the tbody 1st...i guess you could raise the fuel pressure with that, i mean, youll gain like a hp, if you raise it just right, but you would have to dyno tune it for that...
Old Jul 15, 2002 | 06:09 AM
ttt
Old Jul 16, 2002 | 03:17 AM
Mista Bone's Avatar
D Tranny Guru
dyno time.............
FYI D15B7, Z6 intake maifold ported out, CRX Si cam, Stillen header.......
Stock fuel pressure settings on the B&M FPR gave the best power at 118 whp hp.
D15!
Old Jul 16, 2002 | 05:17 AM
88_SC_CRX_Si's Avatar
New User
The MAP sensor "should" notice more air moving through the intake. Sooo, it will tell the ECU to increase the injector pulse width, to handle the increase...
Old Jul 16, 2002 | 05:50 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: How do I know when to increase the Fuel Delivery? (88_SC_CRX_Si)
MAP has no clue.
You need to look into speed density vs. mass air flow systems.
Old Jul 16, 2002 | 06:05 AM
crx(gator)'s Avatar
Default Re: How do I know when to increase the Fuel Delivery? (Mista Bone)
what t-body did you use? how much did you port match the intake manifold...etc...
Old Jul 16, 2002 | 06:39 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: How do I know when to increase the Fuel Delivery? (crxgator)
Like I said before, MAP has no clue.
Old Jul 16, 2002 | 06:51 AM
I think the only way the MAP (Manifold Air Pressure sensor) will notice the change is to reset te ECU.The ECU will then spend the first 20-30 minutes learning new information from your driving.Then the MAP sensor should notify the ECU of the changes and can correct Air/ Fuel changes up to 10%.If I've learned what I've read correctly?
josephcmiller2
Engine Management and Tuning
Mar 21, 2012 03:42 PM
Pippen_001
Jul 25, 2006 07:45 PM
hondacivic4g
Jul 16, 2002 12:35 PM
