Engine Swap. Help!
Old May 12, 2008 | 05:04 PM
struggle51's Avatar
Default Engine Swap. Help!
I'm about to do a swap on my 97 Ek. I have a 98 B20 block with a type r head. I have the B-series axles. I'm thinking of putting in a GSR tranny but they told me it's not recommended cause of the gear ratio(can anybody comment on that). Now they told me I still need the ECU and the mounts. Does anybody know what kind of mounts I need. Also any recommendations on the ECU, I was told SI was a good way to go especially if u wanna chip it. Please any body with any Input on this situation! Thanks
Old May 12, 2008 | 05:20 PM
nix94delsol's Avatar
Default Re: Engine Swap. Help! (struggle51)
Get hasport mounts
the ECU that goes with the motor
GSR tranny should be fine
try to keep the tires on, this motor has a nice tourque curve
Old May 12, 2008 | 05:23 PM
turbo-2nr's Avatar
well since it is a b20vtec you will need a chiped obd1 ecu
Old May 12, 2008 | 05:34 PM
Default Re: (turbo-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-2nr &raquo;</TD></TR><TR><TD CLASS="quote">well since it is a b20vtec you will need a chiped obd1 ecu </TD></TR></TABLE> overlooked the GSR head
Chipped P28 should work
Old May 12, 2008 | 06:32 PM
struggle51's Avatar
Default Re: Engine Swap. Help! (nix94delsol)
Thanx, now hassport but is there a specific type. and also I have no ECU so wich one u recommend i buy.
slowej1
10
Jun 13, 2007 05:13 PM
lowsiciv
Nov 15, 2006 08:21 PM
motrayEG6
Oct 29, 2006 09:41 AM
b18civicdx
Aug 10, 2004 08:46 PM
My92LuDe
Aug 24, 2002 08:24 AM
