Hard to start in hot weather
Old May 12, 2008 | 04:43 AM
phique2000's Avatar
Default Hard to start in hot weather
My wife has a 1991 CRX HF. Whenever it gets hot outside, and her car is sitting in the parking lot all day at work, it won't start when she's ready to go home. It turns over fine, just won't start. If she raises the hood for about 10 minutes, it will usually start then.
A guy I work with says it is probably the ignition module, that he's seen it before.
Before I lay out $100.00 for a new one, I was hoping to get some other opinions.
Anyone seen this before?
Thanks in advance for your help.
Philip
Old May 12, 2008 | 05:35 AM
HOODLOVER's Avatar
Default Re: Hard to start in hot weather (phique2000)
turn the ignition on and listen for the fuel pump to prime.. if it does...i would say to pop off your dist. cap and check rotor,cap,and contact points... its possible its an ignition module
Old May 12, 2008 | 05:54 AM
redboy183's Avatar
Default Re: Hard to start in hot weather (HOODLOVER)
main relay??
Old May 12, 2008 | 08:08 AM
(760)doogie's Avatar
Default Re: Hard to start in hot weather (redboy183)
i was reading about the main relay and thats what happens when the main relay goes bad, its the solder joints in the main relay and when it gets hot i believe the joints become for restrictive, you can take it out and find the weak solder joints and resolder them but research how to do that.
Old May 12, 2008 | 08:57 AM
efras's Avatar
I had the same problem with my CRX. The terminals on the igniter corroded and would not give a good contact. I cleaned them up and has worked fine ever since. Might try that.
Old May 12, 2008 | 09:53 AM
mar778c's Avatar
Community Builder
Community Influencer
main relay
Old May 13, 2008 | 12:56 AM
yuletak's Avatar
Sounds like main relay. In my 89 DX hatch, sometimes if I open the door to let the interior cool out a bit, I can get it to fire up. You can google for pics and how-to.
Old May 13, 2008 | 07:37 AM
~sp33~'s Avatar
EFB055
Default Re: Hard to start in hot weather (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
+1
Thats what solved my problem with hot starts.
Old May 13, 2008 | 04:23 PM
importfan7's Avatar
Default Re: Hard to start in hot weather (~sp33~)
my integra i use to have had trouble starting in the hot weather and i just changed the spark plugs and wires and gave it a tune up and it was fine after that!
Blazinmiller
Mar 12, 2024 10:32 PM
Brand
21
Sep 8, 2022 09:39 AM
collkid
13
Sep 16, 2015 09:10 PM
imoua
11
Jul 28, 2006 08:14 PM
reddigitaldragon
Oct 20, 2003 08:14 AM
