Burning anti-freeze? 91 LS
Old May 12, 2008 | 01:25 AM
Mastergunnie's Avatar
Default Burning anti-freeze? 91 LS
Hey, I’ve got a 91 ls, and lately I’ve smelt what I thought was burning anti-freeze, granted I saw no smoke, so I checked the level and it was low so I filled it and thought nothing of it because the smell went away for about a week then it started again checked the level and it was low again, so I checked the presser, no problem there so I bought a new cap filled the fluid again and just yesterday I smelt it again checked it and EMPTY. I’m out idea’s, I can’t figure out why I only smell it when the fluids low or why the fluids even low. I don’t drive it that hard at all. O and I am sorry about any grammar or spelling errors I’m not the best writer.
Old May 12, 2008 | 03:05 AM
94rs94's Avatar
Default Re: Burning anti-freeze? 91 LS (Mastergunnie)
How old are your hose?
I had the same problem and you might want to try this. Fill it up again, and squeeze the hose and see if you see and coolant coming out. If not, ride around till the temps reach normal. After they reach normal ride around for a bit more then go home. Pop the hood and again squeeze the hose with a towel, the upper hose then the lower hose. What you might see is that one of the hoses will have a small hole. The hole can only be seen at this stage when the hose has expands a bit.
Since the car has been running, the hose will expand just a bit opening the small hose. My hose were expanding way too much because they were old, so I got both of them new. Like you I was wondering where was it going because I saw no smoke, it was small enough to come out when it cooled it was gone and couldn’t see it or hardly couldn’t see it. Since they were expanding way more I didnt need to squeeze, but when it cooled I didnt see it. New upper and lower hose and problem was fixed. Also, check the heater hose...and change even if they dont have a hole..might as well if you are going to changed the other hoses.
Old May 12, 2008 | 07:38 AM
Tizight's Avatar
Head gasket?
Old May 12, 2008 | 11:24 AM
helpmycivic's Avatar
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">Head gasket? </TD></TR></TABLE>
X2
Old May 12, 2008 | 11:26 AM
NAmodified's Avatar
headgasket needs to be replaced, or you have a bad hose or clamp.
If a clamp isnt tight enough it can leak. if its leaking you should be able to smell it. then try and trouble shoot. If there are no leaks. Your head gasket is f'd up.
Old May 12, 2008 | 11:49 AM
integra_101's Avatar
It could be a head gasket.
Same thing happened to me. I had too much pressure in my system. luckly it wasnt my head gasket.
Old May 12, 2008 | 11:50 AM
before you go to bed, put ur car in the garage and jack it up in the front. Leave it jacked until you wake up. If you see antifreeze on the floor then you have a leak.
Old May 12, 2008 | 01:39 PM
Tizight's Avatar
You should do a compression test.
Old May 21, 2008 | 07:54 PM
orchidrider's Avatar
bump! my 91 integra burns antifreeze aswell. i drive it for more then like 20 min and when i get out i can hear it boiling into the resivior(sp?). i seen a lil coolant around the top edge of the radiator. i think it might have a leak. and my hoses are in good shape.
Old May 26, 2008 | 02:24 AM
bump
DonPantalones
Nov 9, 2009 07:25 AM
Bobhonkey
Nov 14, 2008 11:24 AM
EARLdaSQUIRREL
Dec 1, 2005 04:30 PM
alclark
Sep 15, 2003 10:06 AM
tFUnK
Jan 2, 2003 12:56 AM
