Over Heating B16
Old May 9, 2008 | 09:25 PM
Ek4 life's Avatar
Default Over Heating B16
Ok guys here's the deal, Just a few days ago my Si has been over heating. Prior to the over heating about three weeks ago I got my timing belt, water pump, tensioner, and my valve adjusted. Now my car over heats after 3o miles of driving it. And when the AC is being used my idle is really low like the car is dieing. And when im shifting gear to gear the car doesn't over heat till i'm at my final gear which is 5th and when on fifth gear, car over heats again... If any body knows what could be the cause that'd be greatly appreciated. But on monday its going back to the shop where i can give my complaints too which was the prior person who worked on it.
Old May 10, 2008 | 03:21 AM
rockfresheg's Avatar
Default Re: Over Heating B16 (Ek4 life)
hate to be ghetto...but try bypassing the fan...the plug that the thermo switch connects to, just unplug it and stick a paper clip into the contact points...the paper clip should be like a u bend and the fan will stay on the whole time ignition is on...see if that will stop from overheating???
Old May 10, 2008 | 05:08 AM
Ek4 life's Avatar
Default Re: Over Heating B16 (rockfresheg)
But my fan works fine... It turns on when it needs too.
Old May 10, 2008 | 06:36 AM
95dxsir2's Avatar
sounds like maybe they didn't bleed it or top it off all the way
Old May 10, 2008 | 06:39 AM
mikeycivic's Avatar
Default Re: Over Heating B16 (95dxsir2)
i was gonna suggest air pocket as well.
Old May 23, 2008 | 11:08 AM
hondataems's Avatar
Default Re: Over Heating B16 (mikeycivic)
u guys think my sleeved block would overheat because i have air pockets and my top hoes heeps blowing off
arielb1
10
Oct 23, 2019 05:22 PM
NVMYDC
Mar 21, 2011 09:21 AM
BORI4LIFE
Sep 8, 2007 07:34 PM
Bense
16
Oct 29, 2004 06:25 AM
fullcollapse0085
May 2, 2003 10:58 PM
