Overheating problem!
I got a 93 civic dx hatchback and am having problems with it overheating.
*It only over heats when I pull off the highway after driving for a while and put it in neutral
*The radiator doesnt take any coolant from the reserve even if the coolants low in the radiator
*The top pipe gets warm and the lower one is cold
*When I switch the air vents to blow cold the coolant creeps up when the cap is off.
Any ideas on what it could be? Im in a really big hurry since I got a 2 1/2 hour drive ahead of me and dont have any time to search
Re: Overheating problem! (drmix)
Still overheats!!
*Replaced the thermostat
*Fan turns on
*Mostly over heats when driving on highway
*Top hose gets hella hot to where I can barely touch it for long
*Bottom hose gets a little warm but nothing like the top one
*Have to fill up coolant in the radiator almost every time I drive
*Only takes coolant from reserve once in a while
Any ideas?
*Fan turns on
Any ideas?
Re: Overheating problem! (ImportCracker88)
Yeah it does smoke white but thats only when the engines cold...once it warms up its fine.
Also my heater blows cold air after it idles for a while but once i start driving again it gets warm
aha! ok, if your losing cooland to the point have have to routinly add it, you have a leak somewhere. now you said you were getting smoke on cold startup, it it is from coolant, it will smell little sweet. once the cat gets hot, it will cover up a head gasket leak. so hence is why you only see it when its cold. however, the head gasket should keep the coolant form circulating. the abilty for the radiator to take in form the bottle depends on the hose between them to be free of clogs, and the cap's one way vacuum valve to be good [ which is usually whats wrong] and the system to be able to take and hold a small vacuum such as when the system cools off. if you changed the t- stat and did nto put it in backwards, then i think the coolant may not be circulating. if the heat works the water pump is good. i am curious to know if the radiator may be clogged. an easy way to know is disconnect the hoses, and run a garden hose through it. but this only shows flow, and not its ability to dissapate heat. if you run the car and keep seeing bubbles int he radiator while its running, then its definitaylt a head gasket
Re: Overheating problem! (fastrc2)
Hmm its starting to smoke more and more it seems. Also has a weird idle when i start it like it bogs out a little...im beginning to think it may be the head gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drmix »</TD></TR><TR><TD CLASS="quote">Hmm its starting to smoke more and more it seems. Also has a weird idle when i start it like it bogs out a little...im beginning to think it may be the head gasket</TD></TR></TABLE>
check your oil dipstick if it has like a milky material your head gasket is blown since is sputtering i think is your head gasket ....that sux for your two hour drive.....
Re: Overheating problem! (elektronsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNKIE DUCKY »</TD></TR><TR><TD CLASS="quote">
Just went and checked the oil didnt really look milky just like normal oil. However the coolant in the reserve did have a oily look to it
Re: Overheating problem! (mudd_butt)
my car was doing the same thing. I replaced the thermostat, checked for leaks. Fan wasnt coming on so I got that to work, car still overheated. White smoke would come out from underneath my hood. So is my car having the same problem "bad head gasket"??? hows a good way to check to see if your water pump is in good working condition? thanks.
Just went and checked the oil didnt really look milky just like normal oil. However the coolant in the reserve did have a oily look to it</TD></TR></TABLE>
definately head gasket as the problem gets worst itll start sputtering more and more sometimes itll even should the water out of the exhaust
Re: Overheating problem! (jvaughn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvaughn »</TD></TR><TR><TD CLASS="quote">my car was doing the same thing. I replaced the thermostat, checked for leaks. Fan wasnt coming on so I got that to work, car still overheated. White smoke would come out from underneath my hood. So is my car having the same problem "bad head gasket"??? hows a good way to check to see if your water pump is in good working condition? thanks.</TD></TR></TABLE>
if the water pump is bad itll heat up really quick because the water isnt circulating which bad water pumps cand end up blowing your head gasket .......if your water gets in to your oil it becomes a mess
is having a hard time starting probably cuz water is getting into your combustion chamber take of your spark plug and see if any of the cylinders are wet
if theres water there then is gonna be your head gasket replace head gaske if your oil is milky you gotta flush the whole system .........and thats a bitch good luck
TeamInertia619
09-28-2015 05:42 PM
jeremyrocksursox
10-20-2009 05:54 AM
