possible to fix PWR barrel intercooler?
Old May 9, 2008 | 04:25 PM
Garage 808 Hatch's Avatar
Default possible to fix PWR barrel intercooler?
so mine had a leak internally. it sat for a week and filled my motor with water, and hydro locked on cranking.
Old May 10, 2008 | 06:05 AM
tony1's Avatar
Default Re: possible to fix PWR barrel intercooler? (Garage 808 Hatch)
Luckily during cranking there probably isn't enough cylinder pressure to hurt anything. Pull the plugs, crank it over and get the water out, change the oil, and put a good intercooler on there.
Old May 10, 2008 | 08:59 AM
onefstek's Avatar
Just like tony1 said, you should be ok. Just replace the intercooler and you should be good after you take the water out and do an oil change.
Old May 10, 2008 | 03:03 PM
Default Re: (onefstek)
i'm still gonna disassemble it. it sheared the starter shaft off. and this is the JB welded block that had a nice crack across it. what do you suggest for an intercooler Tony?? i like the PWR barrel due to the confines of the EF engine bay. although i may be changing my setup all together
Old May 10, 2008 | 06:03 PM
redboost10's Avatar
Default Re: (Garage 808 Hatch)
just a thought, but thats probably why it cracked the first time...the motor fought its way through and did not get hydrolocked. if you think about it, isnt the crack right where the crank mains are in the center?
Old May 10, 2008 | 06:29 PM
Default Re: (redboost10)
the crack was about 1 inch below the end of the head studs.
Old May 11, 2008 | 02:12 PM
viet_boi_racin's Avatar
damn things are just not working out for you. Best of luck to ya getting the car back up and running.
Old May 11, 2008 | 02:20 PM
Default Re: (viet_boi_racin)
ya, i'm parting out the turbo kit etc, gonna go 84mm GSR prolly with a gt40r or 42, not sure. time to sell some crap off to buy the new stuff
93supercoupe
May 24, 2005 04:44 PM
mamaboy
Aug 10, 2004 07:57 PM
Sinner
Jun 22, 2004 06:47 PM
djdxm
Jun 16, 2002 12:56 PM
austrian type-R
Mar 8, 2002 02:00 PM
