Spark plug / Wire Recommendations for B18C.....
Old May 8, 2008 | 08:17 PM
White94Civic's Avatar
Default Spark plug / Wire Recommendations for B18C.....
Fixing to swap in this B18C into my EG Hatch, but I thought it wouldn't be a bad idea to put a better set of plug wires, and obviously replace the plugs....
It's a completely stock engine, I just wanted something a little better than OEM plugs/wires. ANY RECOMMENDATIONS????
Thanks,
-Ant-
Old May 8, 2008 | 08:21 PM
geebs's Avatar
Default Re: Spark plug / Wire Recommendations for B18C..... (White94Civic)
replace them with a set of new oem plugs and wires.. cant go wrong with that.
Old May 8, 2008 | 08:22 PM
elektronsi's Avatar
Default Re: Spark plug / Wire Recommendations for B18C..... (geebs)
ive got bosch platinum +4 and magnacore wires in my EM1, and same thing in every other car ive owned, no problems, great spark
Old May 8, 2008 | 08:25 PM
rhino87's Avatar
NGK?
Old May 8, 2008 | 08:44 PM
Schister66's Avatar
Man U FTW
Wires: OEM replacements
Plugs: NGK replacements at OEM gap spec
Old May 8, 2008 | 09:13 PM
So just from the quick response from everybody, I'm guessing there's no benefit of buying lower resistance wires then at this point???
Old May 8, 2008 | 09:38 PM
Neebs's Avatar
Can't go wrong on both plugs and wires with NGK.
Old May 8, 2008 | 10:13 PM
GG99's Avatar
Default Re: (Neebs)
magnacor wires + ngk v power plugs
Old May 9, 2008 | 12:11 AM
jgraham0326's Avatar
yeah man NGK ftw they are the best as far as i have seen and they are pretty cheap. and i have msd wires and i havent had any problems with them.
Old May 9, 2008 | 05:57 AM
geebs's Avatar
Default Re: Spark plug / Wire Recommendations for B18C..... (jgraham0326)
i dunno if your timing belt cover has the sticker but most sohc timing belt covers say NGK blah blah.. NGK is oem.. its whats from the factory.. bosch is european.. put them in your vw
Old May 9, 2008 | 06:18 AM
Schister66's Avatar
Man U FTW
There really is no point to running lower impedence wires and the multi-tip spark plugs. If your car is stock and in good running condition, you should have no issues with stock replacement parts. I know how tempting "better-than-stock" parts are, but there's no use paying for something which isn't going to have any sort of positive effect.
Think about it...if Honda could simply change the factory spark plugs they use and in turn get better gas mileage and more power, dont you think they would have done that already?
Old May 9, 2008 | 08:23 AM
skcivic4life's Avatar
Default Re: (Schister66)
NGK FTW!
Old May 9, 2008 | 08:50 AM
lsdB16aEj1's Avatar
Default Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">Can't go wrong on both plugs and wires with NGK.</TD></TR></TABLE>
x2
Old May 9, 2008 | 09:17 AM
miguel329's Avatar
Default Re: (lsdB16aEj1)
deff ngk....
Old May 9, 2008 | 10:50 AM
GG99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Think about it...if Honda could simply change the factory spark plugs they use and in turn get better gas mileage and more power, dont you think they would have done that already?</TD></TR></TABLE>
its all bout costs son
Old May 9, 2008 | 05:40 PM
lilo_goki's Avatar
i have ngk iridium IV spark plug and they're fine.
LDForget
Honda CR-V & Element
11
Oct 15, 2012 11:11 AM
Notorious_T
Feb 19, 2009 08:33 AM
kim_2_da_chee
32
Jul 26, 2004 09:59 AM
acura0gsr0ntegra
Oct 15, 2003 04:08 PM
SilverIntegra
Apr 2, 2002 08:32 AM
