gt35r on a b18c, where do I connect the coolant lines for turbo?, also endyn breather Q
Old May 7, 2008 | 01:47 PM
rice is nice's Avatar
Default gt35r on a b18c, where do I connect the coolant lines for turbo?, also endyn breather Q
So below is a picture and I labeled a few things on it, with regards to my gt35r i'm going to be putting on a b18c motor I got from a parts car.
Are 1 and 2 where I connect my endyn breather catch can, and 3 where I install a freeze plug to block where the old charcoal canister was?
Number 4 was connected to the charcoal canister, do I plug this up, what thread is that pipe, so I can just plug it.
Can I connect the coolant lines to my gt35r to number 5 and number 6? If so, anybody know what thread size these are so I can get a XX to npt fitting so I have nice earls lines for my turbo? Which one should be hooked up to the inlet and which to the outlet of the turbo? Any specific size hose needed? (I know garret told me no less than a 10AN on the oil return to the oilpan)
Finally I heard from somewhere that you shouldn't use a T fitting on the oil pressure sending unit like this 18c previous owner did for the oil inlet line, is this true? Where is a better spot?
Thank you all, the other few pics are of the project car, and my small garage.
Old May 7, 2008 | 01:57 PM
litovi3tboi503's Avatar
Default Re: gt35r on a b18c, where do I connect the coolant lines for turbo?, also endyn breather Q (rice is
You will have to plug hole #3. #1#2 can be used for your catch can. # 5 and #6 can be for the coolant for the turbo. #6 goes to the throttle body correct? #4 will have to be plug or if you can bring it to your catch can.
Old May 7, 2008 | 02:00 PM
StolenTeg's Avatar
That a lot of stuff you got hooked to the pressure sensor plug
Old May 7, 2008 | 02:03 PM
mrbigg9032's Avatar
Your really not supposed to have any other senors or fittings coming off of the pressure sensor hole.. Especially all the crap u have hanging off there. It should be remote mounted with a ss line so when the engine moves and bounces around the sensores dont break off.
Old May 7, 2008 | 05:35 PM
well "I" didn't do that T fitting thing. I got this motor from a car I bought Which is why I'm asking you guys what I should do, cuz i thought it looked odd just hanging there.
Old May 7, 2008 | 05:37 PM
I'm not going to use a FITV or IACV on this car cuz its just for drag racing. But anybody know what threads those coolant and crankcase lines are so I can get adapters for them?
Thanks again guys.
Old May 7, 2008 | 08:14 PM
Old May 8, 2008 | 06:28 AM
up
Old May 8, 2008 | 07:05 AM
HiProfile's Avatar
You'd probably want to use #6 for the coolant to the turbo, then use the original end of that line for the outlet. In most cases, it always dumps into the water tube connecting the t-stat housing to the water pump. There are other ways to route it, but you want water to flow through at a decent rate.
Also be careful removing that oil mess. Inspect the block's threads closely, since they likely forced an NPT fitting in the BSPT hole, which can ruin the block's threads if done with too much force.
Old May 8, 2008 | 11:45 AM
What thread is that oil hole anyway? Cuz I'm probably going to take ur guy's advice and remote mount it elsewhere.
Old May 8, 2008 | 05:04 PM
what thread is that coolant line number 6 also?
Old May 8, 2008 | 09:26 PM
are numbers 4, 5 and 6 pressed in fittings or threaded in fittings?
hastingsr
Apr 24, 2009 05:15 AM
sohc_kuhol
May 27, 2008 03:31 AM
redlseg
May 15, 2005 04:32 AM
It's*BOLO!!
Mar 30, 2003 03:19 PM
boosted_zc
Mar 8, 2003 04:27 PM
