My fuel setup, you comments are welcome and appreciated. (LONG)
Many thanks to Dusin and Art, they helped a ton with this.
Will it work???
<u>FUEL SYSTEM </U>
(1) 12mm x 1.25 -6AN 90 degree hose end, part # EAR-849091
(Connects directly to top of stock fuel pump bracket)
(X) -6AN Stainless Steel Hose
(1) -6AN Straight Swivel-Seal hose end, part # EAR-800106
(Connects to inlet of Aeromotive Fuel Filter)
(1) -10AN to -6 AN reducer, part # 991914
(Allows use of -6 line to and from the Aeromotive fuel filter since it has -10AN ports)
(1) Aeromotive Fuel Filter, part # AEI-12304
(Connects to outlet of Aeromotive Fuel Filter)
(1) -6AN 90 degree tube Swivel-Seal hose end, part # EAR-809106
(Connects to inlet side of AEM fuel rail)
(1) -6AN Union, part # EAR-981506
(Used to connect swivel seal fittings)
(1) AEM Fuel Rail
(Connects to outlet side of AEM fuel rail)
(1) -6 45 degree tube Swivel-Seal hose end, part # EAR-804606
(Connects to side inlet on Aeromotive FPR)
(1) Aeromotive FPR, part # AEI-13109
(1) -6AN Econ-o-fit blue, part # EAR-900206
(Connects SS line to stock return line)
Did I forget anything? How much SS hose should I order?
Will it work???
<u>FUEL SYSTEM </U>
(1) AEM Fuel Rail
And dustin...what is with the stat o seal for the stock fuel filter bulkhead? I didn't see any pictures, what needs to be done there?
9/16" Stat-o-seal, part # EAR-178009
(Seals bulkhead fitting on stock fuel filter bracket)
I've also added these to the shopping list:
-6AN port plug O-ring seal, part # EAR-581406
(Blocks off extra Aeromotive FPR inlet)
-10AN Buna O-rings, part # EAR-176010
(Seals reducers on the fuel filter)
Dutin ordered 25 feet of the ss line to run to and from the tank. If you want to really save money use 3/8 aluminum or steel pipe instead of the ss hose. It'll be stronger, last longer, and CHEAPER. For 25' of pipe its only $15, where as hose will be over $100. But you need a 3/8" tube beader to flare the end so you can mate the hose ends to it. I did this with my water cooled bearing housing, but if I ever have the time I will do that to the fuel lines also.
art
art
Nova_Dust
10
Aug 10, 2006 08:16 PM
