JDM b16 swap. USDM p30 going BARR, throwing a code 23 - knock sensor
Old May 3, 2008 | 05:06 PM
B16CXer's Avatar
Default JDM b16 swap. USDM p30 going BARR, throwing a code 23 - knock sensor
everything has been swapped for the BARR and i drive it around and it starts throwing a code 23..
i replaced the JDM knock with a USDM one (extra motor) i had...
resetted the ECU, and after passing 4-5k once vtec kicks in..CODES
Timing and all that is rite, fresh gas, idles fine...etc..
im lost? and i wanna get this BARRed asap...
JDM motors n JDM ECUS dont have KNOCK? or what?
any help would be greatly appreciated.
thanks
Old May 3, 2008 | 05:47 PM
ekb16's Avatar
did u check to see if the wireing for the KS is going to the correct spot on the ecu
Old May 5, 2008 | 05:56 AM
B16CXer's Avatar
Default Re: (ekb16)
thanks...fixed it. followed the wiring, had the aftermarket 3plug for the CX
the sensors were switched =p
no more code!
its so easy to get the plugs mixed up cus they all fit the same...
93sidelsolvtec
Jan 22, 2007 03:50 PM
Jonzo
Jun 25, 2005 11:28 AM
noob23
Aug 27, 2004 03:59 PM
justmotor13
Aug 18, 2003 12:11 PM
jdmciviceg
Jun 9, 2002 07:56 PM
