Spun rod bearing
Old Jul 13, 2002 | 11:53 AM
Mover's Avatar
Default Spun rod bearing
I'm pretty sure my my #1 rod bearing has been spun.
I'll be rebuilding the motor sometime in the future, however, I was looking for a 'quick fix' if possible.
Could I drop the oil pan, drop the rod, piston and reinstall new rod bolts along with new bearings for the bad rod/piston ?
Any other ideas ?
Old Jul 13, 2002 | 12:26 PM
YeuEmMaiMai's Avatar
Default Re: Spun rod bearing (Mover)
bite the bullet and just do the rebuild
Old Jul 13, 2002 | 12:53 PM
blufke's Avatar
Default Re: Spun rod bearing (YeuEmMaiMai)
spinning bearins sux. my friend did that in his crx and his avenger both in like the same week.
Old Jul 13, 2002 | 01:31 PM
earl's Avatar
How do you know #1 spun? You might be able to pull the #1 rod end cap. If rod and crank look ok, replace the bearing. But normally a real rod bearing spin will freeze the motor, wreck the rod and mess up the crank. It would take a full tear down rebuild if that happened.
Old Jul 13, 2002 | 07:57 PM
Mover's Avatar
Default Re: Spun rod bearing (earl)
By the sound its making (higher pitch metallic rap) and the frequency that sound occurs. If it was a main bearing, it would make a deeper sound.
I adjusted the valves to make sure they weren't loose. Did a leakdown
as well. BTW, its an H22A motor
[Modified by Mover, 11:58 PM 7/13/2002]
Old Jul 14, 2002 | 07:15 AM
earl's Avatar
But why #1 as compared to #2,3,4? I'm sure it's not a spun bearing as the engine would only run a minute in that condition. Could be piston slap, worn out piston pin or most likely a rod bearing going bad. You need to fix it now before more damage is done. Drop the pan and check your rod bearings first.
Old Jul 14, 2002 | 07:35 AM
Mover's Avatar
If it was piston slap, I would have noticed it coming on. ie I know it would be worse when the motor is cold as compared to hot, but thats not
the case here. Its consistent cold or hot.
I'm guessing its # 1.... thats where I've tracked the sound to be originating from.
Like you said, a piston pin or rod bearing is probably going bad.
If I could take care of it by going thru the oil pan alone, that would be a bonus.
[Modified by Mover, 11:36 AM 7/14/2002]
Old Jul 14, 2002 | 08:11 AM
earl's Avatar
With the engine running, pull spark plug wires one at a time. If it is a bad rod bearing or pin, the noise will go away when you pull the right wire. I once had this problem, isolated the bad cylinder, pulled the rod cap and the bearing fell out in 4 pieces (thanks to running nitrous). Replaced bearing and was good as new.
Old Jul 14, 2002 | 03:23 PM
Mover's Avatar
Thanks for the info.....do I have enought room to pull out the rest of the rod and piston from down there ?
Old Jul 14, 2002 | 06:06 PM
earl's Avatar
NO...and if you could, you would never get it back in
Mitch11Bravo
Feb 26, 2015 08:42 AM
AssPenny
13
Feb 22, 2014 07:51 AM
Baron55
Aug 28, 2006 12:37 PM
IVAN93EG
Jun 24, 2006 09:27 PM
