Suspension & Brakes Theory, alignment, spring rates....
HELP! Uneven tirewear even after alignment!
Old May 2, 2008 | 02:35 AM
EG6R's Avatar
Default HELP! Uneven tirewear even after alignment!
After only 1,000kms my front tires are again completely bald on the inside. Ive had the alignment checked and fixed in two different shops. The car still pulls noticeably to the left even after the alignment.
Camber -1.5/-1.5
Caster (split) -.3
Toe 0/0
Now, I am guessing that when i get on the road thats when the alignment starts to go out of spec. Thats why the shop thinks its fine until i start driving out.
The lower ball joints, bushings and tierods are bnew. All other suspension parts checked ok. Tires/wheels have been rotated/checked/balanced.
The UCA balljoints are still intact but the rubber boot around it is torn.Will a busted/loose upper balljoint cause a MASSIVE change in alignment??
Ive read that toe out will cause the inner part of the tires to wear. So i must have a great deal of toe out. (?)
Old May 2, 2008 | 06:03 AM
hatchling37's Avatar
Default Re: HELP! Uneven tirewear even after alignment! (EG6R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">Will a busted/loose upper balljoint cause a MASSIVE change in alignment?? </TD></TR></TABLE>Quite possibly so. But you said the shops you took it to checked all the front end parts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">Now, I am guessing that when i get on the road thats when the alignment starts to go out of spec. Thats why the shop thinks its fine until i start driving out. </TD></TR></TABLE>
This tells me that you have bad parts, my first guess would be a wheel bearing.
Toe in causes inner shoulder wear. Honda spec wants it to be at 0. Wheel alignment is not your issue, it's your bad parts. Do you have SAI readings along with Included Angle?
cilvia
Mar 23, 2011 05:28 PM
Paulybrownktown
21
Jun 29, 2009 03:35 PM
whteteg8901
Suspension & Brakes
Apr 6, 2008 09:35 PM
ware
Feb 14, 2007 06:18 PM
b16a2EBP
May 8, 2006 12:47 AM
