SOHC TURBO TRANNY QUESTION...
Old May 1, 2008 | 08:31 PM
d_EG COUPE's Avatar
Default SOHC TURBO TRANNY QUESTION...
wat tranny would be best if i go sohc turbo??? or would it be better if i custom a tranny???
Old May 2, 2008 | 05:38 AM
mrbigg9032's Avatar
Sohc tranny's suck but best out the box is the s40 from a EX/SI. It has shorter gears then its s20 brother, steel shift forks and larger bearings. What r ur power goals? If you only trying to make 200-300 wheel then the s40 should hold up ok but I would recommend getting a LSD..
Old May 2, 2008 | 06:20 AM
hatchling37's Avatar
Default Re: (mrbigg9032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 &raquo;</TD></TR><TR><TD CLASS="quote">Sohc tranny's suck but best out the box is the s40 from a EX/SI. It has shorter gears then its s20 brother, steel shift forks and larger bearings. What r ur power goals? If you only trying to make 200-300 wheel then the s40 should hold up ok but I would recommend getting a LSD..</TD></TR></TABLE>
SOHC transmissions can be very reliable, even with big power. I would highly suggest a full refresh on bearings and seals, and make sure your synchros are satisfactory. Both trannies have are identical (gear-wise) look it up.
An LSD is definitely recommended, I agree.
As for the OP, what are you going to do with your car? Road race? Bonneville? That's a VERY vague question.
Old May 2, 2008 | 07:25 AM
mrbigg9032's Avatar
Default Re: (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">
As for the OP, what are you going to do with your car? Road race? Bonneville? That's a VERY vague question.</TD></TR></TABLE>
Reading &gt; You I said EX/SI. THere r 2 differant s20 trannies one for the EX/Si and other for the LX/DX. The one from the 92-95 EX/SI (s20) has the same gearing has the 96-00 s40.. Last time I check they didnt make a d series SI in 96-00 that why i wrote EX SI
Old May 2, 2008 | 12:41 PM
d_EG COUPE's Avatar
so which 1? s20 or s40???
Old May 2, 2008 | 01:37 PM
fishnfst's Avatar
Default Re: (d_EG COUPE)
You want any 92-95 ex or si tranny... The 96-00 ex's had steel shift forks that are paper thin and only have a very small contact point at the weld.. I can bend the forks by hand.. I went through 3-4 of the 96-00 trannies.. People kept saying they were better.. Then I took apart a 92-95 tranny with the aluminum forks and those things are beefy.. THey have a huge amount of webbing that the 96+ trannies do not have..
So I repeat 92-95 ex or si tranny will do you right... SYnchro wise the D-series trannies take a beating.. THey are only single cone synchros and do not do well at high rpm's..
Old May 2, 2008 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 &raquo;</TD></TR><TR><TD CLASS="quote">Last time I check they didnt make a d series SI in 96-00 that why i wrote EX SI</TD></TR></TABLE>Clarity &gt; You. You made the statement S40 in EX/Si. Your '92-'95 Si's didn't come with S40's. They have an S20 label and the stamp on the case near the axle hole says B000, as opposed to the S20 in the LX/DX that has A000. The S20 (B version) and the S40 (out of '96-'00 EX's) have identical gear ratios. That's what I was saying. It's all good, chief, I see what you are getting at, but the OP pretty much stated that he doesn't know about D-series trannies, and I was trying to clear that up.
Old May 3, 2008 | 06:32 PM
d_EG COUPE's Avatar
soooooooooo S20 then out of a 92-95?
thanx guys
Old May 10, 2008 | 10:51 PM
Rtboy10's Avatar
i make 300hp and have a 98 ex trans and i blew out 2nd gear twice within a week go with a gearspeed trans and you will never have a problem again
Old May 12, 2008 | 05:08 PM
d_EG COUPE's Avatar
well i juss picced up a s20 woot woot
confusion
23
May 14, 2008 08:46 AM
NateEK99
Jul 22, 2006 04:16 PM
Wazup
Jun 8, 2003 10:27 PM
