Check Engine Light on Stock Motor?!
Old Jul 13, 2002 | 10:00 AM
VoltageLS's Avatar
New User
Default Check Engine Light on Stock Motor?!
Hey guys, I haven't done anything to my motor yet and it WAS fine until about a couple days ago. All of a sudden I had the CEL light up and flash once quickly when my car was in aux mode. When i started it up, it just stays on continuously. Do I have to be in diagnostic mode in order to correctly confirm what code i'm throwing, or can I just tell by the flashes upon startup of the car? If i go by the latter, it should be :
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
Any help on trying to fix that? Thanks guys!
Old Jul 13, 2002 | 02:16 PM
Chiovnidca's Avatar
Default Re: Check Engine Light on Stock Motor?! (VoltageLS)
You have to jump the SCS connector.
Old Jul 13, 2002 | 02:41 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Check Engine Light on Stock Motor?! (Chiovnidca)
go under your glovebox and find the green rubber thing. pull out the connector that's in it and connect both holes with a wire. turn your car to ON (do not start it) and watcht he CEL.
long blinks signifies 10's digit (ie 4 long = 4X)
short blinks signifies 1's digit (ie 6 short = X6)
so 4 long,a dn then 6 short would mean 46.
Old Jul 13, 2002 | 08:36 PM
firered's Avatar
think simple first, could be a routine maintenance requirement for the manufacturer to get more money. check your milage, the owner's manual should say when routine checks are required. 99 out of 100 there is nothing wrong.
Old Jul 13, 2002 | 10:58 PM
thaiphob's Avatar
Nikon!!!
check your gas cap. same thing happened to me>>>>check your GAS CAP!
Old Jul 14, 2002 | 03:17 AM
Chiovnidca's Avatar
Default Re: Check Engine Light on Stock Motor?! (firered)
That would be indicated by the maintenance light, not the CEL.
patpeery
Apr 4, 2008 02:40 PM
tpod
17
Mar 1, 2006 12:41 PM
Hatch It
Oct 25, 2004 06:15 PM
thenglishman
Aug 24, 2004 08:50 AM
Charlie Moua
Jan 2, 2003 10:20 AM
