check engine light???
Old Aug 22, 2004 | 12:46 PM
thenglishman's Avatar
Default check engine light???
I have a 92 GS and the check engine light just started coming on and staying on untill i turn my car off and restart it. I also noticed that the engine temp goes up and stays up. The needle stays in the same place (in the center). Is this my O2 Sensor or something else... the car also idles rough, dropping anywere from 800RPMS down to 200RPM's... sputtering, that kind of thing...
Old Aug 22, 2004 | 01:09 PM
3.504's Avatar
Default Re: check engine light??? (thenglishman)
you need to check the CEL code. look at the first post in the integra forums about "ecu codes found here" and it will tell you how to check the code. once you do that, come back here w/ what code number it flashes and then we can diagnose some problems.
Old Aug 24, 2004 | 08:50 AM
Default Re: check engine light??? (3.504)
I found the connector and and put a piece of wire in it, i turn the ignition on and the CEL just stays on, doesn't blink, doesn't do anything. The second i pull the wire out it goes off...
Modified by thenglishman at 11:12 AM 8/24/2004
bigodub93
20
May 19, 2010 01:49 PM
patpeery
Apr 4, 2008 02:40 PM
ph0shizzle
May 13, 2006 08:36 PM
si 1
Mar 31, 2006 12:35 PM
