Swapped B16A2 in EK, often struggles to start or idle properly
Old May 1, 2008 | 04:58 PM
Azxster's Avatar
Default Swapped B16A2 in EK, often struggles to start or idle properly
I have 3 issues with this B16A2 in my Civic, using a P28 with a stock B16A2 chip.
The starter is fine, however sometime it takes longer to start the car.
Sometimes, when I start the car, it idles like ****, about to stall for like 10 seconds. Throttle response is slow at this point.
Sometimes, when I am waiting at an intersection, idle drops to 500 for a moment.
What the hell is wrong with this car? What should I look into? Could it be ECU, distributor cap/rotor/wire, some kind of sensor, bent valve? Can a chip fry an ECU?
Old May 2, 2008 | 09:19 AM
s13_maJiK's Avatar
Default Re: Swapped B16A2 in EK, often struggles to start or idle properly (Azxster)
do you have correct fuel pressure? If its idleing rough too check TPS sensor?
Old May 2, 2008 | 09:49 AM
Ice78transam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azxster &raquo;</TD></TR><TR><TD CLASS="quote">I have 3 issues with this B16A2 in my Civic, using a P28 with a stock B16A2 chip.
What the hell is wrong with this car? What should I look into? Could it be ECU, distributor cap/rotor/wire, some kind of sensor, bent valve? Can a chip fry an ECU? </TD></TR></TABLE>
symptoms sound like vacuum to me
Old May 2, 2008 | 01:45 PM
Default Re: Swapped B16A2 in EK, often struggles to start or idle properly (Ice78transam)
bump for help
Old May 2, 2008 | 01:56 PM
raidacaipo's Avatar
check your CEL code.. tell us what codes its throwing
Old May 2, 2008 | 09:18 PM
Azxster's Avatar
Default Re: Swapped B16A2 in EK, often struggles to start or idle properly (raidacaipo)
No code, does a bad TPS throw a code? When it idles like ****, throttle response is delayed, is this a sign of bad TPS?
Old May 3, 2008 | 11:12 AM
Not necessarily. But look into it. Its not difficult to rule out.
Old May 3, 2008 | 12:39 PM
99rhdek9's Avatar
check your crank angel sensor
Old May 3, 2008 | 08:25 PM
raidacaipo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azxster &raquo;</TD></TR><TR><TD CLASS="quote">No code, does a bad TPS throw a code? When it idles like ****, throttle response is delayed, is this a sign of bad TPS?</TD></TR></TABLE>
from my experience I would say that sometimes the tps doesnt even throw a code and yes if its not properly adjusted or its in bad shape then most likely your idle will drop and bog when your on neutral at a stop light. your throttle response will be delayed and so on. its easy to adjust.
Old May 4, 2008 | 10:59 AM
xzodiackillerx's Avatar
I would say TPS ... I had the same problem with my old car and I changed the TPS and never had the problem again
smokinloc
Mar 8, 2010 01:39 PM
baulum
Mar 24, 2008 08:15 AM
WTB AUTO EK
Jan 20, 2007 11:44 PM
blazinb16
Jan 24, 2003 05:31 AM
