gear issues
Old May 1, 2008 | 02:47 PM
96_h23's Avatar
Default gear issues
recently my car started having trouble going into gears and yesterday it got worse. i can only go from the position of third gear to neutral to fourth gear i cannot move over to where fifth and reverse or first and second are. the weird part is when i let out the clutch the car is stuck in the reverrse gear regardless of the shifters positon. this car is my daily so i gotta get this fixed asap.
any ideas as to what the problem could be?
all help is greatly appreciated!!
Old May 1, 2008 | 04:52 PM
96_h23's Avatar
Default Re: gear issues (96_h23)
bump...
Old May 1, 2008 | 05:27 PM
CALC!_JUST_du_IT!'s Avatar
Default Re: gear issues (Jimmy)
I'm almost certain you have damaged something in your shift linkage. You probably just lost a bolt on the freeway. You might be slamming on your shifter too hard...
Jack the car up and inspect your shift linkage. This is probably something you can fix for less than $5. Let us know how it goes!
Old May 1, 2008 | 05:59 PM
96_h23's Avatar
Default Re: gear issues (CALC!_JUST_du_IT!)
thanks i really apprectiate it. i jacked up the car and couldnt really see anything. the linkage appeared to be in good order. i'll figure it out haha i was overdue for a clutch anyways
Old May 2, 2008 | 11:56 AM
96_h23's Avatar
bump
Old May 2, 2008 | 11:58 AM
Jimmy's Avatar
Global Moderator
There's a chance your clutch disk/pressure plate is failing on you.
slowesteg
K Series
Oct 2, 2018 09:49 PM
ej193
14
Mar 3, 2009 01:42 PM
JDMGSR-T
Oct 27, 2006 02:48 PM
eMbrace
May 14, 2005 07:47 AM
mojord
13
May 21, 2002 08:08 AM
