type r caliper question??????????
so i just picked up a 95 civic hatch with a 5 lug conversion i beleive the conversion was off a 2000 or 01 went 2 bleed the brakes and the nipple was stripped every shop said i need a new caliper my QUESTION IS i was told a early year tl or rl calapers r the same is this true? someone tell me what calipers compare 2 the type r so i can go to a local junk yard and pick them up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donvito#1 »</TD></TR><TR><TD CLASS="quote">so i just picked up a 95 civic hatch with a 5 lug conversion i beleive the conversion was off a 2000 or 01 went 2 bleed the brakes and the nipple was stripped every shop said i need a new caliper my QUESTION IS i was told a early year tl or rl calapers r the same is this true? someone tell me what calipers compare 2 the type r so i can go to a local junk yard and pick them up
You can get the Legend calipers from a junkyard , and i believe they are better than the ITR caliper .
</TD></TR></TABLE>You can get the Legend calipers from a junkyard , and i believe they are better than the ITR caliper .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekBlackHatch »</TD></TR><TR><TD CLASS="quote">prelude/crv same caliper as itr, the legend is bigger i think dont quote me.</TD></TR></TABLE>
legend (certain years) is two piston as opposed to 1
If it's just the bleeder screws you could always just replace those instead of new calipers.
for the dual pistons... Dual piston calipers came on all 93-95 coupes and 94-95 GS sedans... GL finding them at a junkyard. they're not impossible to find, but they just don't come up that often.
PM me back if you need 2 piston legend calipers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi »</TD></TR><TR><TD CLASS="quote">I would just use vice grips to remove the stripped bleed screw.</TD></TR></TABLE>
ITR calipers have more clamping force, but IMO Legend calipers offer better modulation and more even pad wear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec »</TD></TR><TR><TD CLASS="quote">
I would just stick with the ITR caliper, Honda chose that for the R for some reason?
^ x2
</TD></TR></TABLE>I would just stick with the ITR caliper, Honda chose that for the R for some reason?
^ x2
YaMaJeSty
21
Jan 7, 2004 09:01 AM
