DPFI idle adjustment (searched)
Old Apr 29, 2008 | 11:54 AM
bigrob119's Avatar
Default DPFI idle adjustment (searched)
Subject...now residing in the Arizona desert and left my shop manual back home in California.
Car runs fine under throttle but idles 100-200rpm low, worse with the AC on. Bad enough to the point where it will stall when cold with the AC on for a few minutes until it's warm. Just need to adjust the idle up a couple hundred RPM, can't find it anywhere here on HT or the web.
Haven't touched anything under the hood, other than an intake & exhaust it is a stock engine '89 LX, DPFI.
Modified by bigrob119 at 10:30 PM 4/29/2008
Old Apr 29, 2008 | 09:28 PM
bigrob119's Avatar
Default Re: DPFI idle adjustment (bigrob119)
C'mon now, don't tell me NO ONE knows. Help a brother out.
Old Apr 30, 2008 | 08:57 AM
welfarepc's Avatar
your ECU controls your idle....
there is a flat head screw on the throttle body... ive tried to play with it but never been able to increase my idle speed.
mark its original position so you can turn it back when nothing happens
Old Apr 30, 2008 | 02:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Old Apr 30, 2008 | 04:09 PM
bigrob119's Avatar
Default Re: DPFI idle adjustment (88DXCRX)
Thanks a million for the pic.
Appreciate it my good man.
Old Apr 30, 2008 | 05:39 PM
Big red89's Avatar
Mine did the same and i adjusted it at that point in the pic and now its fine..
Old Apr 30, 2008 | 10:18 PM
MIGPA26's Avatar
Mine did the same thing, I needed to change out the pcv valves which had about 75,000 miles on them and for some reason i had to tighten the throttle linkage bolt on the thottle body. After that mine was fine havent had a problem since its been 3 months problem free.
I dont know if these items are it but might help
Old May 1, 2008 | 03:12 PM
bigrob119's Avatar
Adjusting the idle via the screw in the pic helped a ton, there's still an occasional stumble once in awhile that I believe is ignition timing related. +
The fact that I need to get off my *** and install my new O2 sensor (that I've had laying around for months) doesn't help either.
Old May 1, 2008 | 10:23 PM
MIGPA26's Avatar
Default Re: (bigrob119)
my occasional stumble was the pcv valve
georgiajdm
Aug 11, 2009 06:31 PM
NAmodified
Dec 5, 2007 04:04 PM
carblegal
Dec 25, 2004 09:51 PM
civic-lsi-vtec
16
Dec 24, 2004 05:26 AM
delSolLS
Jun 19, 2001 09:05 AM
