P1259 Vtec Malfunction Problem
Old Apr 28, 2008 | 07:49 PM
Red_em1_51O's Avatar
Default P1259 Vtec Malfunction Problem
I have a fresh gsr motor that i rebuilt. The bottom end has gsr crank and rod with oversized ITR pistons. The head has a port and polish with supertech Valvetrain. Ctr cams and Skunk 2 cam gears.Blox manifold with stock throttle body. I just broke the motor in and when i get on it it chokes like there is no VTEC what so ever. When i try to get it up to vtec after i try to push it for a while the code p1259 comes up. I have more than enough oil. My Vtec Solenoid is good. I even switched it out with my friends. I am running on a stock 99 civic si p2t ecu. I need help with this..My oil pressure is good too..i have researched for a few days now and checked everything that i could any help would be good. I am also running a b16 obd2 distributor also
Old Apr 28, 2008 | 07:54 PM
Combustion Contraption's Avatar
A mod should move this to tech/misc. or hybrid, it will probably get a better response there.
Old Apr 28, 2008 | 08:06 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: P1259 Vtec Malfunction Problem (Red_em1_51O)
Sounds like a wiring problem. You may have a short. Do a continuity check between the vtec soleniod pin in the harness plug and the solenoid plug.
Old Apr 28, 2008 | 08:12 PM
Default Re: P1259 Vtec Malfunction Problem (mar778c)
i checked it and it was good with 0.2 ohms of resistance thanks for the help
Old Apr 29, 2008 | 09:30 PM
i fixed the problem i did a ls vtec line from the block to the head..i tested oil pressure at the block and it was in spec but i was bearly getting any pressure at the solenoid..
Boner_Ben
May 10, 2008 02:16 PM
98 gsr teggy
Nov 7, 2007 09:01 PM
tuckin15s_8315
Sep 28, 2005 10:12 PM
92eg'n
Dec 6, 2004 11:17 PM
Cyberdx16
Apr 16, 2004 08:17 PM
