Heating problem with boosted LS vtec need help
Hi HT
I just got my boosted LS vtec running and its having a heating problem. It doesnt overheat right away but after some time it would heat up. It would heat up when I come to a stop after driving around even without boosting. I have to stop and let the car cool down.
I have new Mishimoto half radiator with slim fan in a EG. I am thinking the radiator is not able to cool the motor. Also I put in a new thermostat when the motor was assembled.
What do you guys think is the problem?
Thanks in advance.
Paul
Thanks in advance.
Paul
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpwrdeg »</TD></TR><TR><TD CLASS="quote">I am having a similar problem with my B16T, what plugs are you running, if you didn't buy a cooler plug that could be the problem. </TD></TR></TABLE>
spark plug heat range has pretty much nothing to do with coolant temp.
OP, more detials please. is the thermostat opening? does the fan work properly? did you bleed the system?
spark plugs are BKR7E and Im pretty sure the thermostat opens because i can drive around for some time before it heats up. I wired the fan to the ignition so it will be on all the time and the fan is blowing the right direction.
After driving for like say 20 min under boost, the temperature would go up when I stop at light.
I am thinking of getting a Koyo radiator or go with bigger fan or change both.
Anymore ideas?
Anymore ideas?
617ej1
May 4, 2010 04:44 PM
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
DEVIN22CBR
Apr 9, 2003 12:27 PM
