Need Help ASAP...Pilot Bearing????
Old Jul 12, 2002 | 03:21 PM
hybrid_KJ's Avatar
Default Need Help ASAP...Pilot Bearing????
FIDANZA FLY WHEEL. OEM Pilot Bearing Fits Loosely,TRANNY WENT TOGETHER FINE. Is this a problem?
MOTOR OUT OF CAR. PLEASE HELP Soon as Posible.
[Modified by hybrid_KJ, 7:24 PM 7/12/2002]
Old Jul 12, 2002 | 03:23 PM
B19CivicHB's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (hybrid_KJ)
Whats the problem... you were kind of scarce on info...
Old Jul 12, 2002 | 03:26 PM
hybrid_KJ's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (B19CivicHB)
The pilot bearing fits in the fly wheel very loosely would that cause a problem???
Old Jul 12, 2002 | 03:34 PM
IN VTEC's Avatar
Which part has play? The inner or outer race?
You could just buy one from Honda for like $17 if it's suspect.
Old Jul 12, 2002 | 03:39 PM
Rocket's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (IN VTEC)
Yeah that's a problem.
Old Jul 12, 2002 | 03:42 PM
hybrid_KJ's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (Rocket)
If I flip the fly wheel over the bearing will fall out.
Old Jul 12, 2002 | 03:48 PM
Rocket's Avatar
The safest thing to do is not run that flywheel unless you fix the problem by fitting a bearing with a bigger outer diameter otherwise your input shaft bearing of your tranny will suffer.
Good luck.
Old Jul 12, 2002 | 03:55 PM
IN VTEC's Avatar
Did you reuse an old pilot bearing?
Old Jul 12, 2002 | 04:39 PM
hybrid_KJ's Avatar
It was a used bearing, but I tried 2 different bearing and had like results.
Old Jul 12, 2002 | 05:42 PM
hybrid_KJ's Avatar
Actually one was brand new and came with the clutch net clutch kit we are using and the other was the oem one that came out of the stock flywheel. Both had the same results the bearing is loose and will fall out when the flywheel is flipped over. Looks like I will be calling Fidanza in the morning.
Old Jul 12, 2002 | 06:09 PM
ninesecrx's Avatar
Yeah...sounds like you got a jacked flywheel...or the wrong one. That bearing usually has to be tapped in....Mike
Old Jul 12, 2002 | 11:40 PM
hybrid_KJ's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (ninesecrx)
Yea it sounds that way, Im going to call fidonza in the morning. Bummer. thanks for all the help.
Old Jul 13, 2002 | 01:24 AM
sparkz's Avatar
the flywheel is defective. i am pretty sure 99%. so far, i have seen 3 aftermarket flywheels where the bearings "fall" out
Old Jul 13, 2002 | 07:14 AM
TurBoXBirD16's Avatar
Old Jul 16, 2002 | 12:42 PM
hybrid_KJ's Avatar
Default Re: Need Help ASAP...Pilot Bearing???? (xbird)
I called fidanza they told me it would be fine, they said to just throw some lock tight on it. I think im gonna go for it.
Old Jul 16, 2002 | 02:14 PM
non-VTEC's Avatar
if it's so snug that it will hold with locktight then you might be OK.....but with the heat of the engine and vibration it might come loose on you...........tough call......
civic-steve-94
Aug 15, 2015 03:03 PM
frankiebseries
Aug 22, 2009 11:52 AM
alexb18c1
Sep 24, 2008 05:25 PM
vjace
Feb 9, 2005 03:44 PM
